Home Forums Sign Making Discussions Vinyl garment film help need instructions for applying vinyl
  • garment film help need instructions for applying vinyl
    Posted by Chris Windebank on 3 February 2008 at 10:04
    I have some black nylon jumpsuits to do but cannot fond the insstructions. I have in stock printaflex nylon from Dorotape and metamark garment film.
    Question, will the metamark do nylon? if not the doro one will but need some advice on application please
    Steve Underhill replied 17 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Stuart Murrden
    3 February 2008 at 10:06
    hi used nylon material before.Try printing for 3 seconds then let it cool and print for another 10 secs cheers
  • Steve Underhill
    3 February 2008 at 11:05
    If its not the correct vinyl it wont stay on.
    Im not sure about the doro tape and metamark stuff, but nylo flex or nylo cut from xpres is what I use, its a lot thinner and beds into the weave.
  • Barbara Eden
    3 February 2008 at 17:14
    Chris,sorry can’t help with the Metamark,but have instructions here for the Nylo-Flex-if that’s any good?
    Temp 150,for 20 secs medium pressure,remove backing when cool,repress (covered with silicone paper) for further 10 secs.
    Barbara
  • Nick Minall
    3 February 2008 at 17:29
    Is this the stuff here?
  • Steve Underhill
    3 February 2008 at 17:37
    That metatex from metamark would be the stuff to use, I always remove the backing first as its a pain to remove after and sometimes stops the stuff sticking at all.
    20 seconds under a press is a little too long for very thin nylon garments I think, 10 secs peel and repress for 10, thats how I do it.
  • Chris Windebank
    3 February 2008 at 19:02
    Cheers all, never used before and these garments were expensive! used the Doro one and pressed for 10 secs then uncovered and pressed again with a teflon sheet. Looked nice, stuck well but a bit hard but got a happy client.
  • Steve Underhill
    3 February 2008 at 19:10
    I must add, when I say backing I dot mean the plastic backing, i mean the very thin film that covers the xpres one.
