Home Forums Sign Making Discussions General Sign Topics Frame for banners?
  • Frame for banners?
    Posted by Joseph Helm on 18 May 2009 at 20:32
    I’ve got a customer that sells advertising space on the side of his van.
    He wants to change to using banners on the side (because they are longer lasting, and easy to swap)… whats the best/cheap frame system to use?
    Joseph
    George Elsmore replied 16 years, 7 months ago 7 Members · 10 Replies
  • 10 Replies
    18 May 2009 at 20:45
    never used this, but looked good ay sign uk
    http://www.isermatic.com.
    18 May 2009 at 20:52
    good find peter thank you
  • Kevin Flowers
    18 May 2009 at 21:07
    Its like Spirit Display but taken a step further, Spirit Display is just a simple trim to mount to a flat surface but uses the same fastening system
    http://www.spirit-displays.co.uk/uk_about.html
  • Joseph Helm
    18 May 2009 at 21:12
    Thanks for the suggestions guys!
    18 May 2009 at 21:17
    like the idea but is it a once only fit, as after you have trimmed off the excess you can’t refit it.
    or have i got that wrong
  • Kevin Flowers
    18 May 2009 at 21:57
    Chris
    you have got it right, they say you require 100mm on each edge to allow fitting
    18 May 2009 at 22:05
    your right they do say that kev but also show you in the video that you are able to remove part to change light bulbs for light boxes and the like. then hammer back in…
    this is almost the exact same system i used for converting/changing a lightbox into a flex face sign. the downside is when you fix the trim to the light box there is allot of bounce in the wall of the regular lightbox and you need to give it a good firm pelt with the hammer to create the tension pinch so i would think you need their extrusion walls to do that correct if not just better than i did mine. that said that was a few years ago i did that sign and recently saw it and still as good. even though i had only did it back then as a temporary measure.
    i bought my trim from spirit displays and theirs is very much the same so i wonder if spirit are agents for crystal or vice versa.
  • George Elsmore
    19 May 2009 at 09:03
    can anyone remember the name of the company at sign uk that had a tensioning system where a banner was slotted in and the frame sprung open so to speak to create the tension?
  • Derek Heron
    19 May 2009 at 10:45
    quote Peter Normington:
    http://www.signupsystems.co.uk/home.html
    this is who neil who was at the sign uk meal uses
    he is busy away across the country fitting rac banners he loves the system and has fitted some monsters
    will try and post some pics
    Derek
  • George Elsmore
    19 May 2009 at 11:00
    quote George Elsmore:
    cant find it on exhibitors list? did i imagine it???
