Home Forums Sign Making Discussions File Swapping Font Required: Lucida Handwriting Bold
  • Font Required: Lucida Handwriting Bold
    Posted by John Cooper on 5 April 2008 at 12:29
    I have Lucida Handwriting italic but need the bold version (I can add italics manually) but the application I use (embroidery) doesn’t allow me to create a bold font from a non bold TTF!
    Alex Pirozek replied 17 years, 9 months ago 5 Members · 13 Replies
  • 13 Replies
    5 April 2008 at 12:43
    Hi John I dont think it exists 😕
    Lucida handwriting italic appears to be the only hand written version.
    I couldnt find it anywhere on the net
    5 April 2008 at 12:47
    i’ve needed to use it as a bolder font before, so i simply adderd a small contour and welded it together, creating a fatter font.
    i seem to have lost handwriting though, had to make do with ff running text lately!
  • John Cooper
    5 April 2008 at 13:05
    Cheers guys
    I can probably find another way to create it – just being lazy 🙂
  • Ian Johnston
    5 April 2008 at 15:06
    what do u need typed in it john. Easysign allow it to be BOLD.
    Ian
  • John Cooper
    5 April 2008 at 15:21
    Thanks for the offer Ian.
    If you could produce it in a vector format that would be great as I could resize and create stitches.
    This is what I need, justified centred
    NEWBURY SCALE
    MODEL CLUB
    David Lewis
    Just for your info, each letter will be aprrox 10mm high
  • Alex Pirozek
    5 April 2008 at 15:53
    Hi John,
    Could you add more compensation to the lettering to make it bolder or would that make it too messy for embroidery?
    Alex.
  • Alex Pirozek
    Hi John,
    Alex.
  • John Cooper
    5 April 2008 at 16:00
    I did try that but it started looking a bit ‘loose’.
    It’s not desperately important – converting TTF to embroidery lettering can be a bit hit & miss.
  • Ian Johnston
    5 April 2008 at 16:59
    FIND ATTACHED
    Hope it’s what u needed
    IAN
  • John Cooper
    5 April 2008 at 18:12
    Thanks Ian
    Very grateful for your help.
  • Alex Pirozek
    5 April 2008 at 21:09
    John,
    I had a quick play with it, I’m not sure how bold you would like it though. It will still need a little tidying up i think but see if it’s along the right lines.
    I can PM you the file if you like as i can’t upload the file on here.
    Alex.
  • John Cooper
    5 April 2008 at 21:51
    Thanks Alex, you like a challenge 🙂 that looks very good and plenty bold enough.
    Any format will do but .emb preferred. Perhaps you could email to:
    john at stitch-up dot biz
  • Alex Pirozek
    5 April 2008 at 22:02
    Email sent John
    I hope they are OK for you.
    Alex.
