Home Forums Sign Making Discussions File Swapping Font ID needed
  • David Rogers
    23 February 2007 at 08:40
    If it’s just for THAT text – won’t take more than 10 minutes to redraw manually (overlaid on the picture) as it’s just boxes.
    Never seen that as a font before – could it just be as a logo.
  • Derek Hunter
    23 February 2007 at 08:44
    possibly, What would be the best way to redraw this? when i zoom in its all distorted tryed tracing but with no joy. (prob just my skills lol)
  • David Rogers
    23 February 2007 at 08:56
    Import image.
    Pick a ‘thickness’ that best suits one of the ‘legs’ of the text – this can then be extended, rotated etc.
    Just do ALL the verticals (ALL SAME HEIGHT when required)…then all the horizontals…zoom in & IGNORE the background image and make sure the ‘boxes’ are aligned…rotate one for the ‘R’ & ‘K’ and weld the whole lot. Ditch the image, then go round the welded ‘text’ – double click & adjust/delete any errant nodes.
    Job done.
  • Derek Hunter
    23 February 2007 at 08:59
    Thanks mate i will get on that now
  • David Rogers
    23 February 2007 at 09:04
    Here’s one I’ve just done…
    23 February 2007 at 09:08
    Here’s one I just threw together whilst I eat my tea
    23 February 2007 at 09:09
    Dave beat me to it 🙁 As Dave says tho, its just boxes
  • Derek Hunter
    23 February 2007 at 09:50
    Thanks for your advice here is my attempt 😀
    23 February 2007 at 10:13
    well done, see it was easy eh 😛
  • Derek Hunter
    23 February 2007 at 10:22
    Cheers Drew dreading a complicated one :lol1:
  • David Rogers
    23 February 2007 at 10:25
    Not bad mate.
    Just a wee note – just use the one thickness of rectangle for the text & duplicate it over & over…dragging the copies along the same axis, then use the same one & rotate it. That way the text will be more uniform in size…it’s also MUCH faster!
    ps. what software are you using?
  • Derek Hunter
    23 February 2007 at 10:27
    Ok i will keep that in mind thanks
