Home › Forums › Vinyl Cutter Discussions › General Cutter topics › Foison C24 problem
Foison C24 problem
Posted by Ashley Brayson on 20 October 2007 at 15:57Hi everyone,
I’ve just purchased my first ever cutter a Foison C24. I didn’t have much money to play with! I have a problem. Should I be able to see the cutter move up and down between jobs because the blade seems to be scoring the surface when it moves between letters. If I back it off so it doesn’t mark the surface it won’t cut the letters. Apparently pressing the test button on the plotter itself should move the cutter up and down but it moves it very quickly from left to right 🙄When idle how close to the surface should the blade be?
Thank you
Ashley
Graham Tallis replied 17 years, 2 months ago 10 Members · 20 Replies -
Ashley I don’t know that plotter but it should all be in your manual
Hi Lyn,
Unfortunately the manual is very sketchy and translated from chinese in acrobat reader. I think they assume you’ve owned one before 😕Thanks anyway.
Ashley
Ashley – silly question but could the person who sold the plotter tell you?
Not a silly question at all. I just thought I’d ask here before doing that. I was hoping someone else might have the same type as me.
Ive had one of these lying in the house for a month now and last night decided to try and set it up. To say the instructions are all over the place is an understatement and the drivers are as good as useless.
In the end after 3 hours of me and a mate tearing our hair out we gave in. We used the latest driver, installed the Flexisign patch, but no matter what we did Windows could not read the drivers. We checked the device manager in Windows XP and the driver was there just with an error message saying that it couldn’t read them.
I’m going to try to contact Sign Wizard today where I bought it from, but it looks like all their technical support is through the forum, which I find very irritating.
I think I’m old fashioned but I like to talk to someone on the telephone when dealing with problems as constant email/forum ping pong rarely seems to get the job done.
Its true that you get what you pay for, ill have another go tonight then it will be going on eBay and a better package will be purchased.
I just want to stick up for Foison. I sent mine back and they sorted out the problem. Got it back the day after. I’m using FlexiSign Pro which works fine with it . I’ve overcome the rounded corner issue by changing the blade offset to 0.031 instead of the default 0.051.
It now cuts great and I am very inpressed with mine after some initial problems. Stick with it and I think It’ll be worth it. There’s nothing around in this price bracket . This was my only affordable option and to be honest I’m glad I got mine.
I’m only doing basic lettering but it’s fine for me.
Don’t be discouraged.
I know the manual is not great though!
I simply adjusted the blade so it just protrudes from the bottom of the holder. Settings are 100/28 usually. I’ve not adjusted the blade depth at all like the manual states. This must be a typo I think.
Good luck.
Just an update. Tonight I uninstalled everything my mate did yesterday and started from scratch, following the online guide to the letter……It worked fine with Flexisign and has cut a few test pieces a treat.
I dont want to sound like a total fool, but what do you mean by the blade offset?
After you’ve selected cut, the cut/plot window opens.
Where it says send now, click the drop down menu next to it and select hold in list.
Then in the Production Manager window right click on the job you’re wanting to cut in the list and select properties.
In this window click on the cutter tab and go down to the knife offset bar. I think this reads .051 or .51. Change the 5 to a 3.
I don’t know what this does but it improves the accuracy some how.
I haven’t had time to try out other settings but it works for me.
Now and again I have some small areas that it’s skipped but it’s just a matter of cutting with a scalpel.
Hope this helps.
Ashley
Hi Guys,
So im new to the world of vinyl signs and im very interested in buying a cheap piece of kit to start with as i dont want to spend thousands and then chuck it in the cupboard if i get board.
Now i know that Foison cutters are not respected in the slightest with some people on this forum as i have been doing my research, but i am glad i have found someone who finds them ok.
I do have a couple of questions to ask if anyone would be so kind to reply.
Is the software that comes with the cutter good enough to get started and what version of corel draw is best for a beginner like me?Thanks guys
Firstly its good practice to say hello and introduce yourself in the newbie room if you want to make a good impression and reap the rewards of the vast knowledge the members of this board can offer.
As for Foison, IF you can get the thing to work without uninstalling itself everyday and having the supplier blame everything from the USB cable to the brand of dogfood you fed your beloved pet last friday afternoon, then go for Corel X3.
I had a Foison for 1 month and it nearly made me give up and go back to working for Shell (ive still got it actually, its where I hang my clothes when I come in drunk).
Paul
I use Flexisign so I’m not sure what software comes with the plotter. I also use Photoshop for my lettering at the moment.I don’t do anything fancy with the plotter but I’m very pleased with it.
quote Ashley Brayson:Hi,
Odd that by your own admission that "you don’t have much to play with" to buy a Vinyl Cutter, yet you have expensive software? 😕
quote Paul Humble:Hi,
Ok, I will do that but Please forgive me as i am a newbie to forums as well and dont really know the ins and outs.
So seriously am i going to regret parting with my hard earned money on one of these machines as it certainly seems like it?
What are the alternatives on the cheaper end of the market? -
quote :Odd that by your own admission that “you don’t have much to play with” to buy a Vinyl Cutter, yet you have expensive software?
I tend to go for the best software and work from there. I’ve found the Foison to do all I want. Sorry.
how do you manage with photoshop for lettering, I find it quite difficult
Peter -
quote Paul Humble:It was over a grand at last check.
Flexi Starter 8.5 is £57 plus shipping on your favorite auction site…..straight from the authorised distributors complete with dongle, clipart and fonts CD ….bargain I think.
quote John Thomson:quote Paul Humble:It was over a grand at last check.
Thats super cheap John, at that price I shall be buying tomorrow!
You can get a basic flexi free with some chinese cutters but it has limited features it is probably the Flexi Starter, the pro version which is what Ashley has is over 3 grand plus vat
Hi Steve, ive got a Secabo c120. This is the same machine. what you will find is that the software you are using isnt really compatible with the machine. The Secabo came with flexi starter I couldn’t get on with it anyway as I’m used to using Easy Sign. The drivers for the cutter is in that package. The guys at Easy Sign in the Head Office where really help full and help me out a treat. I was using the hgml setting which wasn’t good enough. Also are you using Vista, if so get rid of it strait away as this also makes the cutter do the same thing you said, it cuts all over the place. I bought the package as Vista compatible (is it hell) give us a ring 01726 76445.
