Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters Foison c24 plotter cutting rubber, advice?
  • Foison c24 plotter cutting rubber, advice?
    Posted by Jason Butt on 13 October 2009 at 21:06
    Hello all
    Ive just purchased a Foison c24 plotter for cutting
    rubber and so far having success on simple text only masks which are blasting great but have all sorts of question on how to do images which im hoping joining this forum may help me answer.
    mod-edit
    please see board rules
    Ian Muir replied 16 years, 2 months ago 2 Members · 2 Replies
  • Jason Butt
    15 October 2009 at 07:29
    So carrierng on with this subject could anyone please advise on how to inport a image into signblazer so I can cut the out line of the image when I send it to my plotter as I’m working in sand blast rubber and at present I only require the outlines
  • Ian Muir
    15 October 2009 at 09:45
    A long winded way but one which works on most design software is
    A) if image is a vector then select all and make outlines and fill black, then trace… you got an outline.
    If image is a bitmap then similar but you got to use a bitmap editor before tracing.
    Of course images will trace but tend to trace all internal outlines too so you can delete those you don’t want.
    Of double course some design software does this auto at click of a mouse when set up.
    Then you have outline send to plotter as a hairline or as a fill with no outline depends what output software wants… if you send as a fill with hairline then tendancy is often for plotter to cut twice…
    Ian :lol1:
