Home Forums Sign Making Discussions Vinyl Fluoresent wrap vinyl supplier please.
  • Fluoresent wrap vinyl supplier please.
    Posted by Iain George on 27 May 2018 at 07:59
    As the title says.
    I have been asked to wrap a BSB 1000 Superstock Teams motorbike. They are wanting bright fluorescent Green and Pink.
    I have found most colours on line but not fluorescent. I haven’t got any swatches here to look at either. Could you please point me in the direction of a supplier. Also the design will require some vinyl cutting line. I have some WrapCut here but the plastic around the filament is really tough and doesn’t seem to pull away like i have seen in some videos and the line is down one side so wont go around corners in both directions, hope that makes sense.
    Enjoy the rest of the bank holiday.
    Iain
    Kevin Busby replied 7 years, 6 months ago 3 Members · 5 Replies
  • David Stevenson
    27 May 2018 at 15:02
    If you want to do corners use "knifeless tape design line" it does most corners no problem. Try not to stretch it though as you go round or it tends to slip and make a mess. Their finish line is great as well, really strong buy not so good at curves. Fitted stone guard to this zx10 using a combination of both. 3 times the price of wrap cut though
  • Kevin Busby
    27 May 2018 at 17:06
    I know metamark do a series of Fluorescent vinyls that would work with the colours you need, they do both a promotional 6 month one or a cast 2 year one but because of the colour your not going to get a long shelf life.
    https://www.metamark.co.uk/sign-vinyl/r … ent-films/
  • Iain George
    27 May 2018 at 18:55
    Strangely enough I ordered some from Metamark but as I done it over the phone and just asked for 2 meters to try I think they sent me the promotional one. I will ring them on Tuesday and get the cast. My fault for not clarifying what I needed.
  • Kevin Busby
    28 May 2018 at 09:08
    Check the website as i think the cast has less colours than the promotional, never used it but im sure i noticed it said that somewhere.
  • Kevin Busby
    28 May 2018 at 09:12
    Just noticed if the colours dont work for you then allprint do both a promotional and 2 year one which has 5 colours based on a KPMF cast vinyl
    http://www.allprint.co.uk/fluorescent-s … series.htm
