Home Forums Software Discussions Signlab Software fluid mask signlab
  • fluid mask signlab
    Posted by Colin Hibbitt on 25 February 2010 at 20:36
    Hi folks
    In signlab 8 using fluid mask we have an issue when exporting the images in pdf format
    the costumers receive there images with a yellow patch around the images which i have taken off using this method
    when saved in jpg form there isnt an issue
    is there something im missing??
    colin
    Peter Normington replied 15 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Shaun Harris
    25 February 2010 at 22:05
    Colin
    I had the same problem.
    When the option opens to select what size you want to save the file, there is an option to export as bitmap you need to check that box. Just be aware this needs a massive amount of RAM for large objects. I usually reduce the image to 25% before trying this.
  • Ray Wilcox
    10 March 2010 at 13:08
    The only real solution at this point in time, is to clip the image before exporting, (Transform > Countour Object > Clip Bitmap), otherwise in some software the yellow background will be apparent. Otherwise Shaun’s suggestion will also work.
  • David J Evans
    11 March 2010 at 10:27
    This was a bug and I thought was fixed in the latest release, what version are you using.
    Best regards
    -David
    Cadlink
  • Shaun Harris
    11 March 2010 at 11:10
    signlab 8
  • Colin Hibbitt
    11 March 2010 at 21:37
    hi davis – i also am using version 8
    is there any updates available??
    colin
    11 March 2010 at 21:42
    quote Colin Hibbitt:
    colin
    colin use signlab update to check but build 10 is the latest update
    11 March 2010 at 22:27
    if you open signlab
    go to help and select about, then press "r" you will get your build
  • Shaun Harris
    6 April 2010 at 16:26
    Thanks Peter.
    I’ve got build 04. Can I get auto updates? or do I need to contact Cadlink?
    6 April 2010 at 16:53
    Shaun, you should be able to down load the updates by using sl update. If you update vpm though, make sure you archive any jobs, in the rip and be warned, you will have to reinstall any print queues you have already set up.
    and may not always be able to un archive the print and cut jobs.
