Home Forums Sign Making Discussions Vinyl Flood Coat Window with Vinyl
  • Flood Coat Window with Vinyl
    Posted by Robert_James on 10 January 2014 at 22:27
    Hi Guys,
    Going to be flood coating a shop front window, and also the door which has glass.. I have the measurements, but im thinking of cutting the film on the plotter so i don’t need to trim once it’s applied as i can never trim straight/neatly by hand..
    Im thinking of cutting the vinyl 2mm shorter than the actual glass, would that suffice? need some opinions from people that have done similar before..
    Thanks!
    Chris Windebank replied 11 years, 9 months ago 2 Members · 2 Replies
    10 January 2014 at 23:34
    NO…
    your eye alignment will NEVER be accurate enough.
    best advice i can give you is to cut the vinyl "exactly" the size you require.
    fit it then trim it.
    that is coming from someone that fits 100% dry application, one go one hit…
    if you are applying wet you should have zero issues because you will have multiple goes at laying and re-applying.
  • Chris Windebank
    11 January 2014 at 09:11
    trimming is the easy part, you just have to learn how.
    Loads of videos on youtube, window filming websites
