Home › Forums › Software Discussions › Flexi Sign Software › Flexi / Cadet
Flexi / Cadet
Posted by L J. on 23 May 2005 at 18:51can anyone advise me how to put the driver for the cadet printer into flexi 7.5 please
L JL J. replied 20 years, 6 months ago 3 Members · 6 Replies -
do you mean profile mate?
i think a version of flexi has its own rip so ide think opening the profile you have within that part. im guessing as i have never used flexi, sorry… 😕 -
Flexi has about 6 drivers under Uniform all but 1 is different versions of the Grenadier, but hasn’t one for the cadet!
This is when you are setting up Flexi to drive the cadet.
L J -
We Have 7.5 V5 and that has the Cadet in the setup.
And we do use it.
It also runs the 54″ and we use it but you have to do a lot of experiment regarding colours. -
Hi Marty, thanks for your reply.
All i need to know is how did you get flexi to recognise the drivers for the cadet as these were not standard install on my version of 7.5!! -
These drivers are already in flexisign and not add ons.
Go into production manager then into set up and then into add new setup.
You get a list of Printers, Plotters And Hybrid devices.
Go into uniform and the Cadet is listed there. You then need to set
the port to the IP address of the Cadet.
If your version hasn’t got the Cadet Listed (which Iam sure it has) then
try the set up for the Roland Versacamm Its the same machine.
Remember when you first go into production manager from the file menu you must go into “rip and Print” and not “Cut plot”. -
quote L J.:Flexi has about 6 drivers under Uniform all but 1 is different versions of the Grenadier, but hasn’t one for the cadet!
L Jthat’s what i am trying to get over, the cadet is not under uniform, only grenadier. My version must be slightly older than yours.
Good idea though using Roland Versacam.
thanks
L J
