Home Forums Sign Making Discussions General Sign Topics Flat roof signs
  • Flat roof signs
    Posted by John Harding on 15 November 2007 at 11:48
    Customer has a new unit with the aforementioned flat roof, he wants signage at 90 degrees (vertically) to be viewed from train lines 100 ft away so reasonably large, does anyone have a suggestion how to tackle this – client would prefer not to use banners and I am concerned about fixing into the flat roof re leaks etc – any suggestions welcome
    Thanks in advance 😀
    Steve Underhill replied 18 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Warren Beard
    15 November 2007 at 11:51
    Can you not fix to the face of the building with the brackets extending over the top of the roof and attach the sign to that?
  • David Lowery
    15 November 2007 at 11:54
    Fix direct to roof using rawbolts but before you tighten, use plenty of silicon sealant in the holes, under the metal frame then when bolted, more sealant around the edges of the frame.
    That’s what I did some 8 years ago and there have been no problems as yet (he says with fingers and toes crossed)
  • Steve Underhill
    15 November 2007 at 13:24
    If you dont want to drill into the flat roof which is understandable,
    (Im assuming with letters that big you are making a metal box section frame in a right angle shape to fix the letters to?
    It all depends what the roof is made from, is it pitch, concrete etc.
    If it was concrete I would use 6" blocks or kerb stones cemented to the roof and fix to those with heavy duty bolts.
    Then cover with a fascia if they are visible from the ground.
    What I wouldn’t do though is drill into his roof, if he gets a leak which in turn turns into a roof brought down by water damage, you are likely to get blamed no matter how much silicon you have put in.
    If its a pitch roof, I would be wary of fixing into it at all, weight onto the frame to weigh it down like blocks or sandbags etc, if someone got up there and decided to pick one up and the sign came down guess who’s to blame.
    Id go with big flags
    :lol1:
  • John Harding
    15 November 2007 at 13:30
    Thanks guys for the replies
    Steve you may have something – I wasnt going to using individual letters but thinking maybe vinyls on dibond secured to a frame and hence I like the idea of freestanding kerbstones whatever that you then fix into
    Keep the ideas coming if someone has done it differently
    Thanks again – John
  • Steve Underhill
    15 November 2007 at 13:43
    Ive tried to buy sky hooks before once but everywhere is either out of stock or they just laugh at me,
    I was going to get my long stand, and my diamond shaped roof tiles at the same time as well
    Incidentally the diamond shaped roof tiles is true.
    My Mates dad actually sent him to Jewson for some and he actually waited while they looked at him like he was a complete basket case.
  • John Harding
    15 November 2007 at 18:47
    Well got to site with my bigger ladders and guess what – client was wrong, it isnt a flat roof at all grrr – its a very shallow pitch asbestos roof concealled from view behind a parapet wall so I’m going to tell the client sorry no signs on the roof and try to work out something like warren suggested ie sign protruding up from wall – so if anyone has an idea on that I would be interested.
    I was thinking maybe vertical poles up from wall via key clamp system (like scaff tube) secured with rawlbolts and then sign blank with channel to the rear onto the posts – any thoughts will this work re wind load etc?
    Thanks – John
  • Steve Underhill
    15 November 2007 at 22:36
    Sellotape
    reinforced with blu tac.
    No, I think your idea is excellent, I would go with scaffold poles in a frame type pattern.
