Flat face dibond sign on rails.
Customer wants a raised flat dibond 0.8m x 1.5m oval shape sign and two adjacent raised rectangular ones either side fitted to this aluminium cladding.
Is there a way of using extrusion or some type of rails on both the signs and the building that interlock to make this straight forward. Locators are no good obv and a folded tray is not an option because it all has to match the oval (ie flat)
The signs need to be raised slightly to miss the cladding bolts that stick out on the building 15mm so extrusion would miss thatIs there a special extrusion on the market? Like the interlocking ones used on Ali sign trays ?
Thanks.
