Home Forums Sign Making Discussions General Sign Topics Flat cut letters stand off on plasterboard wall – favourite fixing method
  • Flat cut letters stand off on plasterboard wall – favourite fixing method
    Posted by Alex Crosbie on 10 April 2018 at 18:09
    Hi all
    I’ve fitted quite a few stand off letter jobs in to plasterboard walls over the years but never found one method I’m really happy with.
    I have a job coming up which will involve around 200 fixings for stand off acrylic letters in to plasterboard….. nothing particularly heavy just wondering what others preferred fixing method is.
    I’m not keen on the metal fixings as they never seem to go in the place I want them!
    All views and opinions would be greatly appreciated 🙂
    David Rogers replied 7 years, 8 months ago 5 Members · 5 Replies
  • Iain George
    10 April 2018 at 18:20
    I have always used Rawlplugs the red or yellow one. They have a small lip on them that stops them from falling through. Just make sure the hole you drill is not bigger than the plug.
    https://www.screwfix.com/p/rawlplug-uno … -pcs/22982
    The worm fixing are okay but if they go loose then you have a big hole to cover. Plus also the screws in these don’t always fit down the locators.
    https://www.screwfix.com/p/fischer-self … pack/47347
  • David McCarroll
    10 April 2018 at 19:20
    Yellow raw plugs from B&Q for us, they have sharp ‘wings’ in them which grabs nicely and no.6 screws for small/medium locators and no.8 screws for large locators. 5mm drill bit for the holes does the job.
    We do this weekly and never had a problems. Hope this helps.
  • Alex Crosbie
    10 April 2018 at 21:46
    Thanks both! That’s much appreciated!
    Alex
    10 April 2018 at 22:04
    If its plasterboard and lightweight lettering, I simply use wood screws and screw these directly into the drywall without using wall plugs. It’s quicker, and strong enough to support internal letters
  • David Rogers
    11 April 2018 at 08:13
    I’m like Phil, course thread screw…and that’s it for smaller stuff.
