Home Forums Sign Making Discussions General Sign Topics Flame Polishing
  • Flame Polishing
    Posted by Adrian Hewson on 8 October 2004 at 19:46
    Help guys
    We are new to flame polishing the edge of letters after we have routered them. While it is easy to get shiny edges we are getting over burn onto face of letters, do you use a masing tape to protect the facxe of the letters or wot
    Help please
    Regards Adrian
    Lee Jones replied 21 years, 2 months ago 7 Members · 12 Replies
  • 12 Replies
    8 October 2004 at 20:06
    im far from any expert mate. infact far from it :lol1: . only dabbled in this but, is it not a case of using more of a point on the flame you use?
    or, maybe going back over the same part?
    that may sound daft.. coz i dont know how you are doing it.. i just used a regular blow torch & did the trick for me, but i wasnt looking for anything crystal clear 🙄
  • Adrian Hewson
    8 October 2004 at 21:06
    Thanks Rob but
    We are using a real flame polisher with a very very fine tip, but if we stray off the cut edge at all we are marking the face of the acrylic. The current job is using plexiglass satinice which is a frosted acrylic and the heat on the face of the letter is making the satinice go clear.
    Anyone else got any ideas
    Regards Adrian
  • Mike Grant
    8 October 2004 at 21:57
    I think the trick is to use the correct part of the flame. You should use the middle of the flame not the end of the flame. It is a hard thing to explain on here so use off cuts to experiment on with the different flame settings.
    Also you shouldn’t go over the same place twice, get it right first time or you can over stress the material. Also do not use extruded acrylic and don’t paint or glue the edges once polished as it will start to crack and craze the surface.
    Some colours also don’t like the flame polisher, they will change colour. 😮
  • Andy Gorman
    8 October 2004 at 22:15
    I always find it is a good idea to polish at a consistent speed so the flame doesn’t linger too long on one area. Takes a bit of practice but gives a consistent finish. I would think a satin finish acrylic would be a bit tricky to polish because the satin would polish to clear quite quicky.
  • Rodney Gold
    9 October 2004 at 04:14
    Degussa (rohm) , who supply Satinice (an extruded product) have a CD out detailing how to machine it without geting edges you have to flame polish , they also supply special special tools to cut it without having saw/router marks. the alos supply a gel when applied to rough cut pex edges totally hides the saw mark and gives a polsihed edge affect.
    We flame polish with the covering on (we always cut with it on).
    Bear in mind flame polishing puts huge stress into the material , if it comes into contact with solvents or near solvents (like pex glues) it WILL stress crack, I recently attended a workshop held by degussa on satinice and other products where they spent a great amount of time on fabrication , glueing etc. They have this on a CD too. Ask your supplier for this and their bulletins on the correct glues etc. Their glues are marvellous!!!.
  • Lee Jones
    9 October 2004 at 07:30
    Please excuse my ignorance, but this all sounds very interesting.
    Just ” what is Flame Polishing”
  • Adrian Hewson
    9 October 2004 at 08:17
    Once again many thanks Rod I done know what I would do without you.
    Hi lee
    When you cut acrylic with a saw or a router it leaves a rough edge at the cut. By running over this edge with a very hot flame you make the cut go very shiny (as you have melted the plastic). This is flame polishing.
    REgards Adrian
  • Lee Jones
    9 October 2004 at 11:37
    quote signco:
    Many Thanks Adrian,
    When you say a hot flame are we talking about some kind of butane /propane torch or hotter as in acetylene ?
  • Adrian Hewson
    9 October 2004 at 11:49
    Hi Lee
    Flame polishing should be done with a Flame Polisher, this is a stand alone machine which generates gas from an electrolytic solution which is then mixed with ethanol (dont ask me any more than that). The flame produced is very clean (no carbon deposits) and very small so that you can accurately polish your cuts
    REgards Adrian
  • Mike Rogers
    9 October 2004 at 12:31
    At my last place of employment the lads used a small palm held flame torch (about 6″ high and 2″ diameter) purchased from machine mart for about £18. With a little experience the effects were more than satisfactory
    Mike
  • Andy Gorman
    9 October 2004 at 12:58
    You can use the little micro flame thingies that are used to remove bubbles from dome resin. OK for small amounts of polishing.
  • Lee Jones
    9 October 2004 at 16:01
    quote big G:
    Thanks for all your help, think I have enough info to give it a try sometime when needed, will give the micro flame thingy a go first as we have a few of these knocking about. Thanks again
