Home Forums Sign Making Discussions General Sign Topics Flame Polish help, need to finish off the edges of Acrylic?
  • Flame Polish help, need to finish off the edges of Acrylic?
    Posted by adam scott on 6 December 2006 at 13:05
    hi all
    ive cut my own sheet of acrylic and need to finish of the edges but i hav’nt done it for years and my mind has gone blank. any chance of filling in the blank for me
    ta
    David Rogers replied 6 years, 1 month ago 4 Members · 6 Replies
  • David Rogers
    6 December 2006 at 15:35
    This is how I do it.
    Tools – stanley blade, FINE wet & dry paper (on block), mini gas torch.
    Scrape edges with stanley blade (side on) to get a smooth finish.
    (Optional) Wet & dry paper – when I say fine I mean FINE – do it wet.
    Wipe off residue / dust & peel back the coating about an inch. (trim off)
    Get gas torch eg. pencil torch or ‘bernzomatic’ mini.
    Set flame to a SOFT blue by limiting the air flow.
    Move steadily over the material, flaming INTO unpolished areas – NEVER pointing at what you’ve just done (risk of overheating & ignition). Watch your speed – to fast & semi-polished – too slow & it starts bubbling.
    I’ve done loads of this – from 2mm to 8mm and it works great…also cheaper than buying flame polishing kit!!
    The option is to finish with a buff & brasso / T-cut instead of flaming.
  • adam scott
    6 December 2006 at 15:38
    cheers Dave
    Ill do just that…
  • Andy Gorman
    6 December 2006 at 16:08
    In case you haven’t found out the hard way, don’t clean the panel with meths once it has been polished. 😕
  • adam scott
    6 December 2006 at 16:14
    Thanks Andy
    I did find out the hard way but it was a while ago and it was on a rush job, on site and i had the acrylic ordered in…. I wasn’t best pleased
    6 December 2006 at 21:40
    I had a very reasonable quote recently from
    http://www.pinetree-enterprises.co.uk/
  • David Rogers
    7 November 2019 at 10:04
    Wee video of 8mm clear cast and bernzomatic gas torch….just for fun.
