Home Forums Printing Discussions Roland Printers fj52 solvent CMYKRB to CMYKLcLm setup
  • fj52 solvent CMYKRB to CMYKLcLm setup
    Posted by john cradden on 13 September 2011 at 11:44
    Can anybody please help by telling me what the correct seqance is to inserting my cmykLcLm cartrigage in looking at the printer from left to right i thought the Lc would go in the old blue slot from the CMYkRB set up amd the Lm would go in the old red slot but after looking at pictures of other fj52’s converted to CMYKLcLm it does not appear so, can somebody please clarifie this for me thank you john
    Stafford Cox replied 14 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Stafford Cox
    13 September 2011 at 11:58
    I’m pretty sure it should go (from left to right):
    K C M lc lm Y
    They should also be keyed so it’s in theory impossible to get them round the wrong way??
    Stafford
    13 September 2011 at 12:42
    Would it not be the same as the operators manual John.
    Stafford when you use to convert these machines you didn’t alter things like cartridge sequences did you??
  • Stafford Cox
    13 September 2011 at 12:54
    No, nothing as fundamental as that. A lot of people ran them with no light colours though as the profiling wasn’t great in those days and they used to overink, but that was just a case of running empty refillable cartridges in position 4 and 5.
  • john cradden
    13 September 2011 at 13:00
    Yep its there for old pigment before it was converted to solvent just want to make sure they did change for some reason before i install £360 worth of cartridges and mess things up thx
    13 September 2011 at 16:16
    John, pretty much everything should be the same as the manual for them. The conversion was to allow it to run more corrosive inks so the only real changes were to mechanical items like pumps, heads, tubing that would be destroyed in no time by the solvent inks. The rest of the printer is bog standard.
    Not sure if these ones had the heater conversion carried out as not all machines had heaters fitted but Stafford should be able to answer that.
  • Stafford Cox
    13 September 2011 at 16:23
    To my knowledge, all the solvent converted machines had heaters added. Certainly all of our Jetsolvers did, as did B&P’s Resolve. I can’t really speak for any others though.
    Stafford
  • john cradden
    13 September 2011 at 20:18
    Yep this one has heaters fitted it was converted from new by victorydisgns and badged as a ecojet
  • Stafford Cox
    13 September 2011 at 20:24
    If you ever get stuck with the printer, look for a company called Optimize. I’m sure Mark Elvidge used to work for Victory and probably knows all about them.
