Home Forums Sign Making Discussions General Sign Topics fixing polystyrene letters to breeze block wall – HELP!
  • fixing polystyrene letters to breeze block wall – HELP!
    Posted by Joe McNamara on 1 July 2005 at 22:14
    Hi all,
    Doing a job for the BBC at the moment and need to fix some polystyrene letters (18 inches tall) to a ( painted internal ) breeze block wall.
    I know solvent based adhesives will eat the polystyrene letters, so if anyone is on here tonight and knows how to do this I’d love to know!
    Joe
    Paul Munford replied 20 years, 5 months ago 8 Members · 14 Replies
  • 14 Replies
  • Nigel Pugh
    1 July 2005 at 22:21
    Joe,
    Couldn’t you drop a wire frame behind the letters, screw the frame to the wall and then hang the letters off the frame.
    If it sounds stupid then it’s cus I am and I’m not a signmaker 😳
    Nigel
  • Joe McNamara
    1 July 2005 at 22:29
    no mate,
    they need to be fixed to the wall .
    thanks anyway though
    joe
    1 July 2005 at 23:23
    double sided tape, or if as I presume its for a set, partialy knock masonary nails into the breeze blocks and just pop the styrene cutouts onto them
  • Joe McNamara
    2 July 2005 at 00:00
    ta peter,
    they were the two ideas I had in mind!
    joe
  • Simon Clayton
    2 July 2005 at 07:59
    Thats what we do, knock in a few wire nails into the wall, and photo spray mount the backs of the letters and push onto the nails
    Simon
  • Fran Hollywood
    2 July 2005 at 11:34
    Joe,
    just a few ideas to add to the others. The nails/spray adhesive and the double sided tape sound good but here are few others that have been used on large signs. Hollow out part of the foam and insert 2″ x 1″ batons and fill the surrounding area with expanding foam. When the expanding foam is cured just cut off the excess and then you can screw fixings into the timber.
    If the front face has to be finished you can use a plastic frame fixing bolt that has a large washer and drill and knock into the wall, then fill and paint the face.
    Fran
    2 July 2005 at 11:37
    I usually just do the nail thing, and put silicon on the wall to hold them. Liquid nails is good too, don’t put on a huge amount, just enough to stickem down
    shane
    2 July 2005 at 11:41
    have a look at Frans web site its well interesting
  • Simon Clayton
    2 July 2005 at 14:45
    whats the address Chris?
    Simon
    2 July 2005 at 16:04
    click his www button at the btm of his post
  • Simon Clayton
    2 July 2005 at 16:08
    for some reason i haven’t had any of the buttons at the bottom for about 7 months
    Simon
    2 July 2005 at 16:32
  • Fran Hollywood
    3 July 2005 at 10:04
    Thanks for the comment Chris.
    I was wondering where you found the site, as l haven’t seen the www buttons for a while.
    Fran
  • Paul Munford
    4 July 2005 at 10:30
    For all our poly work we use clear silicone from unibond, note: some of the other brands tend to melt the poly so run a test first.
