Home Forums Sign Making Discussions General Sign Topics fixing dibond to a curved fascia
  • fixing dibond to a curved fascia
    Posted by Hugh Potter on 3 December 2007 at 18:26
    hi all,
    got some 2mm dibond to fit to a curved fascia (x2), 400mm x 2420mm, whats the best way to fix it? as it’s curved i can’t use a frame, and as it’s so thin i’m worried about countersunk holes and the screws pulling thru (single sided white), any fabulous ideas ?
    Hugh Potter replied 18 years ago 6 Members · 10 Replies
  • 10 Replies
    3 December 2007 at 18:50
    i am no fixer but might look at finishing with a 3mm flat bar width to suit.
    it will give a sort of frame and help keep the edges flat.
    also some thing to counter sink in to.
  • Nick Minall
    3 December 2007 at 18:52
    Do you want to hide the fixings? Hugh.
    Nick.
  • Sean Comrie
    3 December 2007 at 18:53
    I was thinking along the same lines as Chris, what is it being fixed to?
    3 December 2007 at 19:02
    hi, it’s going onto the original (georgian style) wooden fascia. would like to hide fixings if possible, i had considered just fixing the two outermost ends, there’s a moulding which would effectively stop the middle from trying to droop, this way the fixings at the ends would not be too visible.
    ta.
    Hugh
  • Sean Comrie
    3 December 2007 at 19:05
    you could also countersink mirror fixing screws and put dome/ flat head fittings over them which would stop the dibond from pulling through, although the fittings would be visible – but could be covered in vinyl or sprayed. depending of the location of the sign you could also use white screwcaps to cover a larger screw head, also depending on the substrate that the panels are being fitted to you could use vhb tape and mastic as the panels are so thin
  • Sean Comrie
    3 December 2007 at 19:10
    if it is an older style fascia could you fit the panels using countersunk screws and then put a moulded wooden bead around the whole sign to tidy up?
    3 December 2007 at 19:25
    any reason why you used 2mm dibond mate?
    3 December 2007 at 19:27
    thanks Sean,
    i think i’ll steer clear of wooden beading! having given it some thought, and read your replies, i think i’ll just fix at each and and use some vhb tape on the back to give it a little more grip, it can’t slip down because of the original moulding around the fascia, but it’ll help support it anyways!
    thanks for the suggestions!
  • John Harding
    3 December 2007 at 20:10
    Hi Hugh
    Done this myself – followed the contour under a curved bay window of a high street shop to cover existing rotten wood fascia. Used 3mm. Measured accurately and cut to size, fixed one end and just wrapped around and fixed at the other end of the curve with screws and white cover caps – the fixings being at the ends hardly noticed.
    4 December 2007 at 06:36
    quote Robert Lambie:
    HI Rob,
    i was gonna use 3mm, but a couple suggested 2mm when i first enquired about this a month or so back!! i got plenty of 3mm in stock, so am happy to use it, i think 2mm was suggested as being easier to bend ???
    John,
    thanks mate, that’s reassure my mind!
