Home Forums Sign Making Discussions General Sign Topics Fittting frosting to an old curved window pane
  • Fittting frosting to an old curved window pane
    Posted by Daniel Evans on 3 December 2019 at 09:14
    Morning all
    I need to fit some frosting to some windows but I’m a bit wary of a few certain panes.
    I can deal with the flat panels but there are a few of the curved ones and I don’t think the frosting will stick.
    Here is an image of the pane in question.
    Ideas?
    Daniel Evans replied 6 years ago 5 Members · 6 Replies
  • David Rogers
    3 December 2019 at 13:03
    Depending how subtle the etch…a matt laminate might work if you have any. Alternatively one of the silly priced cast 3M ones and heat it in.
    3 December 2019 at 13:55
    i might consider possible spray etch paint seams to be plenty about
  • Daniel Evans
    3 December 2019 at 14:27
    I don’t think spray is an option here.
    I’m going to get an image of graphic and maybe I could do it in a cast material.
  • Iain George
    4 December 2019 at 07:55
    Are the backs flat or curved like the front?
    4 December 2019 at 08:10
    I think you can get a cast or decent polymeric etch film. probably William smiths will be able to help advise you on a decent window film.
    your problem is going to be the heat your applying to stretch and cure the vinyl to the glass in these temperatures. you could easily crack the window.
  • Daniel Evans
    4 December 2019 at 08:26
    Hi Robert
    This is my thought, these are old windows and i think I’ll either crack the window or keep cracking the vinyl. Either way I think I’ll pass at the moment
