Fitting individual letters to uneven brick surface
Hi all, setting up a job at the mo and the wall in which the 19mm foamex individual letters is being fixed to, is quite uneven.The block wall itself is perfectly flat, but The client is facing the wall with a rustic red brick which has a very uneven surface, to give the wall an "old-style" look I’m guessing. The brick is actually more like a thick tile, and has a texture like a roof tile. (i will post a picture of brick up tomorrow).
The letters are quite intricate, each about 400mm high and will be needing about three to four jumbo pops per letter (15 letters in all). I obviously want all letters to be perfectly level and flat with each other, however I will be coming across issues when trying to fix the female pop to this uneven surface.
In an area where there is a deep recess in the tile, say, I will need to have the female pop at exactly the right level as the pop which is on a higher level. Would anyone have any suggestions as to how I will achieve level pops? Or possibly another form of fixing?possibly a small threaded bar system? I am outsourcing the entire set-up, from painted cut letters,fixed LEDs, and fixings.
As i said, I will post up an image of the brick ot give you an idea and to make sense of this post!
