Home Forums Sign Making Discussions General Sign Topics Fitting Flat Cut Lettering
  • Fitting Flat Cut Lettering
    Posted by Simon Stonuary on 14 January 2010 at 22:26
    next week i will be fitting flat cut letters to a flat brickwork surface,some of the female receivers screwed to the wall will inevitably fall on the joint between the brickwork courses ( decorative brickwork with quite wide gaps).this will cause the receiver to sit too low, what would you use to overcome this, ps letters already made
    Andy Gorman replied 15 years, 11 months ago 2 Members · 2 Replies
  • John Childs
    14 January 2010 at 22:36
    Use longer screws and pack them out with something.
    Maybe cut down another connector and use that.
  • Andy Gorman
    15 January 2010 at 01:08
    Or, leave them a bit loose where they hit the mortar line. Provided there are some locators that do hit the brick they should be fine. Done this loads of times.
