Home Forums Sign Making Discussions General Sign Topics Fitting a sign to shutterbox
  • Fitting a sign to shutterbox
    Posted by David Mitchell on 30 September 2014 at 16:39
    looking for the best way to fix a dibond sign to a shutterbox.
    im sure theres many ways and i have ideas but this is alwyas th ebest place to seek advice.
    Vic Adair replied 11 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Denise Goodfellow
    30 September 2014 at 17:19
    I think my stepson uses self tapping screws
  • David Mitchell
    30 September 2014 at 18:53
    yeah denise i think its probably as simple as that just incase i was missing something.
    i was thinking countersunk self tapping screws then fit trim over it to hide screwheads
  • Kevin Flowers
    30 September 2014 at 19:01
    If you want a nice trimmed finish look use some 25mm ali angle put rivets through the side, even a mill finished angle gives a nice finish
  • Denise Goodfellow
    30 September 2014 at 19:03
    He says he puts vinyl coloured circles over the countersunk screws.
    Also keep away from the sides as the frame uses thick steel.
    Hope that helps.
    I know if he fits on his own he uses double sided tape to stick the panel to the box before using screws
  • Kevin Flowers
    30 September 2014 at 19:08
    The shutter box itself is folded panel end plates are only 3-5mm steel which drills easy with a decent drill bit. Trim makes a sign instead of a panel stuck on a box
  • David Mitchell
    30 September 2014 at 19:36
    yeah so self tappers does, i was going to use some stockframe trim form signgeer, covers the holes and goves a tidy finish used it once before and it is so much nicer than seeing screw heads
    thanks guy sappreciate it.
  • Vic Adair
    2 October 2014 at 12:48
    3M double sided tape or splayed rivets
