Home Forums Sign Making Discussions General Sign Topics Fitting a flood coated substrate..
  • Fitting a flood coated substrate..
    Posted by Nathan on 11 January 2006 at 19:58
    When installing a flood coated substrate is there anything I need to be aware of, i.e. am I likely to damage the vinyl when screwing into it.
    Nathan
    Paul Rollason replied 19 years, 11 months ago 3 Members · 3 Replies
  • Andy Gorman
    11 January 2006 at 21:34
    Possibly. If you are screwing through the panel, make sure you don’t overtighten the screw. Otherwise the vinyl may twist in the direction the screw is done up after a while. Best thing is to countersink the hole so the screw isn’t in contact with the vinyl.
  • Nathan
    13 January 2006 at 08:35
    Thanks Andy – I think I’ll go with countersinking the hole to be safe.
  • Paul Rollason
    13 January 2006 at 10:21
    Hi Nathan
    We try to drill and countersink the hole before we floodcoat with vinyl, that way you don’t damage the vinyl with the drill.
    We then heat and push the vinyl into the countersink and pierce a hole for the screw to go through.
    When fitting, do up the screw almost all the way with the battery drill and do the last little bit by hand so as not to twist the vinyl.
    cover the screw head with a small circle of vinyl
    Take photos and post on UKSB
    paul r
