Home Forums Vinyl Cutter Discussions General Cutter topics First Vinyl Plotter Help
  • First Vinyl Plotter Help
    Posted by Johnny C on 1 April 2007 at 12:00
    I want to buy a vinyl Plotter for the first time I have a chance to to buy a gerber fast track but i am not sure if this is a good cutter do u know what software runs on this cutter correctly do u need a security device to run this plotter.
    I have some experience using a gerber GSX15 from spandex this cutter needs a dongle and omega software can some one recommend and give me any pointers on the fast track plotter does it have a fraction or tractor feed what sort of vinyl does it use is it good enough to run a small home business.
    any help and advice is welcome
    Johnny C replied 18 years, 9 months ago 2 Members · 5 Replies
  • Brian Hays
    1 April 2007 at 12:16
    A gerber Fastrack is a re-badged Mutoh SC series.
    It’s the software that will need the dongle not the cutter. Just about any software should run it, Omega, Flexi, Signlab & the cheaper ones too.
  • Brian Hays
    1 April 2007 at 12:18
    ….sorry it’s a friction fed machine, not sprocketed. A good machine if you can get it at a good price. Don’t forget you will need some software though!
  • Johnny C
    1 April 2007 at 12:48
    I have only used the gerber software.
    I know the software needs the dongle is there software you listed dont need the dongle.
    The Omega software any one is using the version 2.0 on the fast trek
  • Brian Hays
    1 April 2007 at 16:09
    All the leading Sign Making Softwares require a Dongle. And a good job too. If you buy won’t that doesn’t have one then it’s almost certainly a cracked copy & you won’t get much help with it here.
  • Johnny C
    1 April 2007 at 18:14
    Thank you I want the proper software and want it with good software i work on a leading UK software support team so i will get the omega software as i have use it before i am of to the NEC in may for the sign show to look what is available
