Home Forums Sign Making Discussions Neon, LED, Lighting first sign tray attempt
  • first sign tray attempt
    Posted by Rich Cooper on 26 July 2014 at 20:23
    Hi im looking at making my own sign trays, what sort of tools do i need to buy for cutting and grooving the sheets? and has anyone got any advice on the fabrication? what do i stick the corners with?
    thanks in advance
    Rich Cooper replied 11 years, 4 months ago 2 Members · 2 Replies
    26 July 2014 at 22:11
    First thing it would be best to get is a membership to the forum, not sure what level you need but there is a tutorial on fabricating trays.
    Cheapest way to start would be with a router with edge guide, 90 deg V bit with a 3mm flat bottom.
    You will need a work surface that is flat & rigid enough to ensure that you get an even cut all the way along with the router.
    You will also need some way of cutting the composite sheet unless you already have a way to do that or buy in cut to size but that is probably another question in itself.
  • Rich Cooper
    28 July 2014 at 21:22
    ok thanks for the reply, ill have a look into becoming a mamber.
