Home Forums Sign Making Discussions Neon, LED, Lighting First lightbox advice
  • First lightbox advice
    Posted by James Beavon on 10 November 2008 at 11:37
    Hi.
    Ive just got an order for my first lightbox…Yippie.
    As its my first im a bit apprehensive, so im guessing i need clear acrylic for the front panel and a translucent vinyl.
    Also how do you fix them, as ive been looking at a few out and about and some are fixed onto 2 horizontal wooden batons, is this recommended.
    Tim Painter replied 16 years, 9 months ago 4 Members · 5 Replies
    10 November 2008 at 11:52
    HI Mate,
    you only want clear acrylic if you’re flood coating the whole of the panel(s), if it’s just cut vinyl graphics / lettering then you’ll want the opal panels,
    if you were to put clear acrylic in without covering the whole panel with a flood coat, you’d see all the lights inside.
    cheers.
    Hugh
  • James Beavon
    11 November 2008 at 11:32
    hI,
    Thanks for the reply.
    Yea its only cut vinyl going on there, so im needing the opal ( glad i posted now was gonna get clear 😳 ).
    Just out of interest what is flood coating?
    11 November 2008 at 12:02
    no problem!
    flood coating is the term used for when you cover a whole panel / window with a single layer of vinyl, "flooding" the surface, so to speak.
    cheers.
    Hugh
  • Ross Couchman
    9 March 2009 at 11:49
    look for a 5mm opal in 050 grade
  • Tim Painter
    9 March 2009 at 11:57
    Hugh you want Opal either way to diffuse the light.
    Even if your going to flood coat you will have cut outs in the vinyl to inlay text etc.
    Tim.
