Home Forums Sign Making Discussions Vinyl Firetrucks yellow oracal reflex vinyl URGENT HELP NEEDED!
  • Firetrucks yellow oracal reflex vinyl URGENT HELP NEEDED!
    Posted by Jan Storgaard on 22 June 2010 at 16:42
    Hello guys (and dolls) hope your expierience can help me out.
    I have 10 firetrucks to decorate with reflex from oracal. They need lettering and a larger "S" type graphic (for safety at night).
    Weeding is hell. I.E. If i make a text (4 words) its hard to weed and as time goes, its like the edges (cut) is reconnecting! and weeding gets harder as time goes. ANY hints would help. I tried heating and freezing with no luck, also tried to roll the vinyl tight to get the cuts to open up a bit.
    AND taking out the inner part of an A is very tricky.
    ALL kinda advice/hint etc. is welcome.
    The "s" graphic is going on flat surface ;o)
    Sry 4 not uploading image, but i dont know how. (dont have website to put it on)
    Jan
    Jill Marie Welsh replied 15 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Matt Boyd
    22 June 2010 at 16:54
    are you using a 60 degree blade for the thicker material/reflective? try using a new fresh blade and adjust the force pressure for the material if its a thicker material. do a test cut first and see how it weeds.
  • Jan Storgaard
    22 June 2010 at 17:31
    quote Matt Boyd:
    Hi Matt, well dont use 60 degree, but will try.
    Testcut with new knife i ok but it wears down rather quickly. Also experimented weth pressure on the summa. 125-130g.
    Some wrote that speed should be slow – ill try that as well.
    J.
  • Matt Boyd
    22 June 2010 at 17:50
    when we cut reflective or thicker material we use a 60 degree blade, i know some don’t, they use a 45 degree, but the speed and pressure need to be right. slow the speed down and do some test cuts to make sure the pressure is correct.
    22 June 2010 at 18:00
    Agreed on the new 60° blade and slower speed.
    Also I only use 3M Scotchlite reflective, I tried the Oracal and would rather have a root canal than use it again. It’s brittle and tears easily, at least the engineer grade stuff.
  • Matt Boyd
    22 June 2010 at 18:04
    yeah, as jill says, the 3m scotchlite is a better material…..much better to work with, weed etc.
  • Jan Storgaard
    23 June 2010 at 05:50
    Thx 2 everyone. Ill buy some different knifes.
    @Jill, ill test the 3M Scotchlite reflective, but you know some public authorities always (is always with 2 ll’s ) have preferences. It must be 3m or this and that ;o/
    ONE more ?
    3M Scotchlite reflective – how long durability ?
    Oracal is 7 years.
    Best regards
    Jan
    Denmark
    23 June 2010 at 11:15
    Always has one L but feels like it should have 3.
    I use 3M Scotchlite 280 series rebranded by Gerber.
    (I used to use a 15" plotter)
    Here’s a pdf with specs, it’s 5-7 year high performance vinyl.
    http://www.gspinc.com/downloads/PDF/mat … ective.pdf
    Around here most firetrucks are garage kept so it seems the lettering lasts longer, even though they do get a lot of washing.
    Most fire companies request 3M here.
