Home Forums Printing Discussions Mimaki Printers Finishing of labels
  • Finishing of labels
    Posted by Steve Lamb on 14 December 2010 at 10:47
    Morning all
    A lot of our work on our JV33 is large graphics for varying applications, but we do also a fair few labels too. Most are reasonably smallish quantities, hundreds sometimes more.
    The finishing is a pain in the rear end. At the moment we are trimming each out on plotter then cutting on a sliding guillotine afterwards, long laborious work.
    Anyone got any top tips on a better method of doing this?
    Steve Lamb replied 15 years ago 6 Members · 17 Replies
  • 17 Replies
    14 December 2010 at 12:52
    steve
    cant you half cut with your plotter?
  • Peter Mindham
    14 December 2010 at 15:01
    Hi Steve,
    We half cut with our Mimaki cutter. You mught have a setting somewhere for your plotter to do the same. Basically, it cuts through the backing paper but leaves six I think spots where it has only cut the vinyl. That way they stay in place and be popped out when packing.
  • Steve Lamb
    14 December 2010 at 16:07
    Fellas.
    Thanks for the replies.
    Yes, I think we do have that facility on our plotter, we have never used it though, thought hadnt crossed my mind. Doesn’t the plotter chew it all up if has big gaps with the cutting? We have the Mimaki plotter, must get it checked, be interested to know how to take the labels apart afterwards? tear them, or still cut?
    14 December 2010 at 20:50
    steve
    the mimaki plotter will half cut, no problem, you need to set it up in your software and in the control panel.
    first you do your normal contour cut, then do a half cut after moving the blade holder to position 2, (I have a separate holder for this so leaves the normal plotter blade sharp)
    The half cut in effect perforates the backing paper, leaving the label in position til you "pop it out"
    give me a call steve, if i can help
  • Peter Mindham
    15 December 2010 at 11:26
    Peter,
    You explain it so much better than I could. Works well for us and we do loads of stickers.
  • Stafford Cox
    17 December 2010 at 13:46
    I made a PDF up years ago about how to cut on a CGFX cutter. The Finecut software is a great bit of software and when you get the half cut right, it’s a real help.
    PM me if you need it and I’ll have a rummage for it.
    Stafford
  • Steve Lamb
    17 December 2010 at 14:35
    Peter thanks for the guidance there, appreciated. I may well do that.
    Stafford. That would be great thank you, could you PM me your email, My pm facility is not working for some reason, need to get it sorted out.
    Many Thanks
  • Stafford Cox
    17 December 2010 at 14:44
    quote Steve Lamb:
    Many Thanks
    Hmmm. Bit of a problem there Steve, I can’t PM people on here 😳
    Hopefully someone else will be able to give you my details?
    17 December 2010 at 15:00
    I sent you a pm
  • Jason Davies
    17 December 2010 at 15:11
    Is this possible with a versacamm?
  • Steve Lamb
    17 December 2010 at 15:28
    Got the PM Peter, thank you 😎
    Stafford I sent you a mail.
  • Stafford Cox
    17 December 2010 at 15:35
    quote Peter Normington:
    I sent you a pm
    Thanks Peter.
    Jason, I’m sure there is software to make this possible with a Versacamm but I have no experience of it I’m afraid. Mimaki Finecut is exclusively for Mimaki plotters.
    Steve. Email sent
    Stafford 😉
  • Steve Lamb
    17 December 2010 at 16:11
    Thanks, I will forward to my man in production.
    Have a great Christmas, Im off now for a break.
  • Stafford Cox
    17 December 2010 at 16:13
    quote Steve Lamb:
    No probs Steve. Have a good one.
    Stafford
  • Gary Birch
    17 December 2010 at 16:21
    quote Jason Davies:
    Yes it is but to be honest when we had a try we had limited success and reverted back to trimming out by hand.
    Gary
    17 December 2010 at 21:42
    Just done this as an example,
    the job was set up in signlab, including the serialisation of the numbers,
    but, halfcut does work well on the mimaki, and saves time.
    the labels at the front were popped out to show
  • Steve Lamb
    18 December 2010 at 15:00
    Excellent Peter, thanks
    Will get my production fella to look into it.
    Have a great Christmas all
