Home Forums Printing Discussions General Printing Topics finishing Cut with versacamm
  • finishing Cut with versacamm
    Posted by Emilio on 7 March 2007 at 19:21
    Hi, Im trying to cut vinyl stickers but I have a problem. The file is in perfect conditions, I see the blinking ants. I send to cut with enough pressure, but it seems the cut leaves less than 1mm intact causing me to have to pull the end off when peeling(with 1 it’s no problem, but when I have to do 160 of them it becomes a problem). HELP !Emilio
    Mark Elvidge replied 18 years, 8 months ago 3 Members · 3 Replies
  • Darren Groom
    16 March 2007 at 13:37
    try reducing the cutting speed
  • Peter Shaw
    19 March 2007 at 18:10
    Have you checked that the cut line is a closed graphic?
  • Mark Elvidge
    20 March 2007 at 07:07
    in the q settings set the eps margin to 1mm.
    or if exporting from corel set a image bleed of 1mm around the object in the advanced tab of the export windows.
    dont do both though.
    that will solve it.
