Home › Forums › Sign Making Discussions › File Swapping › File help
File help
Posted by LeeMorris on 20 June 2008 at 18:35Hi
I’m trying to open this file in corel but it says its corrupt its an ai file.
Lee
Nick Minall replied 17 years, 6 months ago 5 Members · 8 Replies -
Thanks colin
It opens now but not like a normal logo its like an A4 sheet with logo on it.It should be just the logo so i can cut in vinyl.
Lee -
Ian
yours loads okWhy did it say corrupt on mine before?
Lee
i could only get it to open in illustrator, it wouldn’t open in easysign for me either.
just saved as a lower version, it probably was a v13 or somethingian
The reason it won’t import is because it is compressed and Adobe use their own method of compression. X4 now gives the correct error message rather than the ‘corrupt file’ message.
Rename your file with a pdf extension and then use the pdf import filter, it should then import ok. (works here in X3 and X4).
Alan D -
quote Alan Drury:The reason it won’t import is because it is compressed and Adobe use their own method of compression. X4 now gives the correct error message rather than the ‘corrupt file’ message.
Alan DThanks for the tip Alan 😀
Nick
