Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters FC8600 & Cutting Master 4 Poll size issue
  • FC8600 & Cutting Master 4 Poll size issue
    Posted by David Hammond on 12 January 2019 at 11:57
    Anyone else experience this issue?
    Just upgraded the computers to Windows 10, Adobe CC,and cutting master 4.
    Connecting to our FC8600 over Ethernet.
    It works, and cuts, the only thing that doesn’t work is the poll size… a bit of a inconvenience, as we use the origin function on the plotter quite frequently, so not polling the media with isn’t much help.
    I’ve drawn a blank checking settings etc.
    Carl Morton replied 6 years, 11 months ago 4 Members · 12 Replies
  • 12 Replies
    12 January 2019 at 17:41
    in days gone by polling only worked on serial then usb not parallel or network, but if its got its own built in network card i would expect it to work. as you say handy to know how much room is left on the width, with out guessing.
    a lot of people going back to cm3 may be try that
    12 January 2019 at 20:41
    It has built in Ethernet, all machines are wired connections no Wi-Fi. Can’t see anything in the manual saying it won’t work over the LAN.
  • Carl Morton
    12 January 2019 at 21:42
    Hi David, this is a complete guess but just check that your firewall or anti virus software is not blocking incoming data from the machines IP address. Had issues like this with machines in the past but not cutters. Hope this works worth a try.
  • Carl Morton
    12 January 2019 at 21:46
    Best way to test my above suggestion is to trim off the firewall and antivirus virus for a couple of minutes while you test the functions.
    13 January 2019 at 10:46
    Never gave the firewall a thought. We’ve switched from Mac OSX to windows, so there will be some bit’s I’m not sure about.
    I did find the attached PDF, which says when setting up the plotter select TCP/IP rather than the driver that is installed… I’m sure I used the plotter driver, will experiment tomorrow.
  • Iain Pearson
    13 January 2019 at 14:10
    Have you checked the HP/GL settings in the Graphtec menu ?
    13 January 2019 at 14:19
    Yes switched it from Auto to GL same outcome.
    Will try TCP IP thing tomorrow
  • Carl Morton
    13 January 2019 at 17:06
    Hope it solves the problem, keep me updated tomorrow.
    14 January 2019 at 08:16
    Done as the document from Graphtec said.
    Added the plotter in CM4, using the IP/TCP option, rather than selecting the driver that is installed, and we’re able to poll size.
    We’re all up and running on Windows :awkward: Let’s see how that goes.
    14 January 2019 at 08:45
    Ahhhh found another little gripe.
    Whilst Poll Size works, when cutting using CM4, you can’t then use Illustrator whilst it’s cutting.
    I’m stuck sat here with CM4 on top of the screen, unable to do anything else in illustrator whilst it cuts :bangshead:
    14 January 2019 at 11:07
    User error!
    Once you’ve clicked send, you can click done, and voila! you’re back using Illustrator whilst the plotter plots.
    We’re now up and running, with the exception of a few fonts that aren’t compatible with Windows from Mac.
  • Carl Morton
    14 January 2019 at 18:41
    Hi David, good to see the problem is solved [emoji16]
