Face fixing foam.
Looking for some advice. Ive been given the job of face fixing alot of 3mm foamex to the side of a building, which has been plyed to fill in a large gap where a window was meant to be. The sheets are going to be full 8x4ft sizes.
Basically i went down to the job to do a trial run….i kinda knew before hand that just screwing on a sheet of foamex would not be a good idea because of the warping issue when the sun hits it, so i used plenty of gripfill (testing on a small area of the plastic to make sure it didnt melt) and then screwed it on.
24hours later. The sun hit it…it was surf central…waves and bulges everywhere. I would have thought gripfill would have stuck it without any problems?. Could this be because the air is so damp at the moment? The ply behind was dry as a bone.
Any ideas? or alternative methods of fixing up these pannels.
Many thanks.
