Hello
Has anyone ever came across a fabric that has backing paper you can pull off.
I’ve been asked to do a wall for another company as a contractor but want to know if anyone’s ever had experience with the stuff as I haven’t
We have done fabric walls before and just used 2" batton on the wall 48" spacer and full drops from the roll.
Upholstered the fabric over a roll of Dacron and it worked out fine.
You could do even width panels and just mount them to the wall as you could use MDF and use full height 2400mm x1200mm, Dacron with fabric on top and tac round the back and mount to the wall.
Could it be 3M DiNoc?
that comes in a wide variety of finishes as well as the better known carbon and wood effects, there are fabric type finishes too.
This is what you’ve described , very different to vinyl on application as you usually do a cut through butt joint, not an overlap joint.
Very easy to put on though .
Please note:
