Home Forums Sign Making Discussions General Sign Topics Extra Brain Power required
  • Extra Brain Power required
    Posted by Lorraine Buchan on 23 October 2003 at 11:09
    I have a customer who wants in simple terms a magnetic drywipe board 900 x 600mm in size
    The problem comes about because he wants something printed on the board but to still be able to write on and wipe off.
    I’ve had a thought about this and come up with the following options:
    1) A normal magnetic drywipe board with a digital print applied – would this be possible to write on write off??
    2) Steel Coated card 0.75mm printed direct with inkjet then laminated with clear drywipe vinyl form hexis then put into a snap frame – is it possible to print direct to the steel coated card? and who might be able to do this?
    3) Sheet of steel with digital print – again would this be possible to write on write off??
    No.s 1 & 3 could again be laminated with the hexis dry wipe
    Any other ideas???
    ruth replied 22 years, 2 months ago 3 Members · 3 Replies
  • AaSk4Stickers
    23 October 2003 at 12:48
    Hi Lorraine
    Do you have to print the extra material?
    Last white board I customised I merely plotted the required componenets from vinyl and applied them to the white board.
  • Rodney Gold
    23 October 2003 at 13:51
    You would be able to write on a digitial print IF you used the correct marker – however the problem would be abraision when wiping it off or the fact that a permanant marker would “stain” the vinyl. Using a solvent which would work on a normal whiteboard to remove writing will kill a digital print in seconds.
    Best is to use a steel back , white vinyl digitally printed and a wipe off type lamination that is solvent proof. We have a white epoxy coated steel plate called Chromodek here in SA which would be the ideal substrate.
  • ruth
    23 October 2003 at 17:29
    Why not just get a magnetic board however you would normally then apply a digital print on clear vinyl then encapsulate with Hexis stuff?
