Home Forums Software Discussions Corel Software exporting CutPath eps from corelx4 and bring into versa
  • exporting CutPath eps from corelx4 and bring into versa
    Posted by George Elsmore on 23 March 2010 at 10:49
    Does anyone else successfully export from and eps CutPath from corel x4 and bring into versa cut only using windows vista home premium as the platform? It crashes versa every time 😕
    ta
    G
    Alan Drury replied 15 years, 9 months ago 2 Members · 3 Replies
    23 March 2010 at 16:30
    Has it just started to happen, is it normally ok? If this is new problem it could be a setting in the eps export. does the file contain things like transparencies.
    I don’t have Versa so I’m only guessing
    Alan D
  • George Elsmore
    24 March 2010 at 08:12
    Alan, it has been happening since i had the versa installed 2 weeks ago, i have tried all combinations of settings and even put back to postscript 1 as advised any more ideas would be welcome
    G
    24 March 2010 at 11:40
    Is it all eps files or only a particular one. I say because sometimes users have a test file, what does the eps contain. Will your RIP accept pdf if so does that work.
    Can you send me the eps and the cdr(assuming not too big) just in case I can see something a bit iffy, either way I can send you a X5 eps to see if that makes a difference.
    Alan D
