Home › Forums › Software Discussions › General Software Topics › Exploring some Help
Exploring some Help
Posted by Chris Wool on 11 January 2004 at 12:06after reinstalling xp pro links dont work
like clicking on a demo in this site i get a new window but it is blank
not just here though any link if there is a link in outlook, explorer will not open
so where is the bit that says do as you are told PLeasevery large hammer at the ready
chris mrsticker
Gordon Forbes replied 21 years, 11 months ago 4 Members · 5 Replies -
sorry mate
i cannot help im afraid. i recently got a new flat screen monitor.
i think its brill! the downside is again, some links/images on the net dont appear or work proper. (not very often i admit)
what i have to do is right click on the link, then click open.
the only bit on this site that does this for me is the “veiw more emoticons” text link. 🙄 -
Chris have you got all the XP updates, there maybe something on ther ethat needs to be installed, also look at your Privacy settings, should be ok from a reinstall though
thank you
whent to remove programmes told it to remove explorer but it said repair instead OKed all well now
when i started this computer aided sign stuf windows did not exsist.
my fustration with xp pro as i have a few niggling problems i woud like to format the disk clean and start again any ideaschris mrsticker
If you have a few nigles (i did last week as well) just back up all of your stuff, and format. easiest way, and only takes a couple of hours to get back to a working pc with programs installed. i would also partition your HD so in the future you have a seperate HD to store all your files on, so when u do re-format you dont have to back up as much , as all you have to then format is your c: drive.
I normaly give my c: drive 30gig and the rest goes to my d: drive. I find 30gig plenty for my programs ect. then the rest 90gig on a 120 hd is more thna enough for all my downloads and games ect.
I posted the solution in an earlier post this works for some but not all what happens is some of the IE dll’s get de-registered for some reason
Fix isAnyone got any problems with IE6 or links opening really slow etc should try this
It made a big difference to my connection
Open an ms-dos prompt window and type the following
to get dos window
START – RUN – type COMMAND – press ENTER. To exit type EXIT.
Type the following hitting enter after each line and OK if it doesn’t “take” it u typed it wrong.regsvr32 Shdocvw.dll
regsvr32 Shell32.dll
regsvr32 Oleaut32.dll
regsvr32 Actxprxy.dll
regsvr32 Mshtml.dll
regsvr32 Urlmon.dlltype exit then enter to exit.
try this even though you think it is fixed made a big difference to me.
Goop.
