Home Forums Sign Making Discussions General Sign Topics exibition boards
  • exibition boards
    Posted by Ade Brown on 2 June 2007 at 12:18
    Looking for a supplier of the aluminum framing for exibition back boards.
    its the stuff that you put together and then turn a screw to lock in pace – you can then put sheets of foamex/correx in
    anyone any idea’s who does this or a similar system??
    Adrian
    Ade Brown replied 18 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • John Harding
    2 June 2007 at 16:59
    Adrian not sure if its what you want but search for marler haley they do a clipframe frame system which you can insert foamex panels etc into
    john
    2 June 2007 at 18:08
    SMP have quite a wide range of aluminium extrusions, not sure if they would have anything suitable for your needs but worth a call.
  • Nick Minall
    2 June 2007 at 18:38
    You mean the boards that are around the walls here…we call them bullshit boards not sure of the proper name though 😕
    2 June 2007 at 18:46
    so does our garage Nick.. we did ours as i think it is a new requirement for btcc
  • Ade Brown
    4 June 2007 at 14:07
    There the ones – i suppose you could call them bullshit boards
    any other supplers?
    Adrian
    4 June 2007 at 14:26
    Adrian, try phoning one of the bigger companies and ask to speak to the production manager, he might be able to tell you where they buy their extrusion from. Worth a shot at least.
  • Martin Kennedy
    4 June 2007 at 22:34
    Hi Adrian
    This ‘system’ for building the structural walls is the same as used to build exhibition stands. Upright poles plus horizontal beams. A couple of the many systems are Foga and Octanorm – links here:-
    http://www.foga-system.com/?p=Exhibition%20Stand
    http://www.octanorm.co.uk/index.php?opt … &Itemid=40
    Martin
  • Ade Brown
    5 June 2007 at 07:39
    Octanorms the one i was looking for!!!
    anyone know who does just the aluminum extrusion???
