Home Forums Sign Making Discussions General Sign Topics exhibition roll ups and pop ups
  • exhibition roll ups and pop ups
    Posted by Jonathan McGovern on 30 October 2007 at 13:12
    Hi Guys,
    I have just started a new company and we are getting out roland print and cut on friday…… we already have an order for 3×3 pop up with podium case and 7 roll up banners
    where is the best place to buy these? are they easy to make? the customer have also requested they all be crystal laminated??????
    jof
    Jason Xuereb replied 18 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • George Elsmore
    30 October 2007 at 13:17
    try these guys they will sort you out
    http://www.displays-2-go.co.uk/?gclid=C … MAodbW1CXA
    30 October 2007 at 23:39
    Ive been buying from easystands.com for some time now… buy various stands in, but often get the budget roll-up stands in with 6 in a box. come with shoulder bag etc too… cost only £15 each.
    i put the budget ones back out at about £150+vat each (customer supplying artwork)… obviously you can do them a bit cheaper but that’s the standard price on the budget model… ill knock a bit off for multiples or if it secures a sale coupled with other signage.
    i buy my grey backed roll up material "gloss" from europoint display. best quality and best price i have found.
    we also do all the better quality stands with overhanging lights, double sided, rotating etc, but depends on customer needs and style of stand before we can quote on that. but as i said, we generally start at the £150+vat mark… hope this helps.
  • Jason Xuereb
    31 October 2007 at 06:50
    Roll up stands are great. Print trim, tape in and your done. Apart from printing about 15 minutes work.
    One lesson I learnt quick is don’t take out the pin from the base until you have taped in the insert. 😀
  • Jonathan McGovern
    31 October 2007 at 07:22
    thanks guys, great help, im not looking forward to doing the 3×3 pop up, but you make the roll ups sound easy.
    I have my versacamm being delllivered on thursday, training on friday, roll ups and pop ups out by wednesday.
    Should be fun! 😕
  • Jason Xuereb
    31 October 2007 at 07:24
    You’ll be fine. I did my first roll up the second day we had our versacam. I just printed with the generic vinyl 1 profile at highest quality the first time around. Now I just use normal.
    Enjoy your new printer.
  • Mike Robson
    31 October 2007 at 09:28
    Pop-ups are a pain in the arse, and for what they cost, I think people can get a lot more effective displays, but that’s another thing
    Roller banners are piece of cake. Just do make sure that whoever is doing the artwork lays it out right. I’ve lost count of the number of times people have not put bleed on the bottom, or put text into the bleed area. Some people just don’t listen!
    And, we’ve taken to putting a couple of staples into the band that sticks to the graphic – we’ve had a few come back where the tape has come unstuck (not usually ones we’ve made, but other mechanisms that customers have had made eleswhere)
  • Jason Xuereb
    31 October 2007 at 09:34
    Mike the ones I’ve seen destroyed and when the client doesn’t correctly pull the banner correctly out or lets it go, instead of letting it roll back in, in a controlled fashion. You can tell because the edges of the insert are all damaged.
