• Excel into X3
    Posted by Lee Ballard on 14 October 2007 at 13:17
    Am I missing a trick here.
    I have a spreadsheet in Excel 2003 and need to import it into X3 to place within another image.
    Can this be done, if so how as I can’t seem to find a way to do it. (hot)
    Many thanks
    Lee
    Steve Underhill replied 18 years, 1 month ago 9 Members · 13 Replies
  • 13 Replies
  • Nick Minall
    14 October 2007 at 13:25
    maybe make it a PDF from Excel then import it?
  • Lee Ballard
    16 October 2007 at 18:45
    Hi Nick, thanks for that though I don’t seem to be seeing that as an option unless I’m missing something.
  • John Childs
    16 October 2007 at 19:19
    That’s something I’ve been meaning to try for ages, for putting parts list on van drawings, but with Illustrator rather than X3. Not got around to it yet though.
    However, if you only want to print, on Macs, we get a utility called "Grab" which allows us to select an area of the screen, copy it, and then paste it as an image into whatever graphics programme required.
    Is something like that not available for the PC?
  • Nick Minall
    16 October 2007 at 20:49
    quote Lee Ballard:
    you will need a PDF maker, you can download some free ones.
    Nick.
    16 October 2007 at 22:44
    corel has a selectable screen grab you used to have to load it first havent used it in a long while.
    17 October 2007 at 08:09
    Its called Corel Capture and installs with the programme, it can be launched from the programme launcher icon on the top toolbar (rocket) or from the Windows start button/programmes/Corel. A very useful utillity with many options.
    Barcode wizard is also there, X3 users will also find legacy stuff from previouse versions (if installed) ie Corel Trace/Corel Texture etc. Signlab users should find a Corel to Signlab option.
    Alan D
  • John Childs
    17 October 2007 at 08:28
    Just tried Excel to Illustrator and it works a treat.
    Prepared a parts list table in Excel, complete with borders, selected the required cells then copied and pasted into Illustrator.
    Obviously it doesn’t have the functionality of an Excel sheet, but it pasted perfectly with editable text, the right formatting, correct thickness borders etc etc.
    It’ll make producing professional looking drawings a lot easier so I, at least, am a happy bunny. 😀
  • Andrew Simmons
    17 October 2007 at 09:22
    Capturing a snapshot is built into Windows, if you press the PRTSC key it will take the snapshot as a bitmap into the clipboard so you can paste it into Paint Brush or more advanced package and then select the area you are after and copy again to paste elsewhere.
    You can also do ALT+PRTSC to just capture the active window/application.
    Andrew
  • Nick Minall
    17 October 2007 at 09:35
    Just tried it with Excel to CorelDraw works fine for me, get text and vectors. just copy and paste
    Nick.
  • Harry Cleary
    17 October 2007 at 10:25
    quote andrewsimmons:
    Andrew
    Cool!!!! 😀 😀 (Harry’s got a new trick!)
  • George Elsmore
    17 October 2007 at 10:45
    clever boy Harry :lol1:
  • Lee Ballard
    19 October 2007 at 17:36
    Wow thanks guys, all sorted.
    Lee
  • Steve Underhill
    19 October 2007 at 18:30
    Incidentally in Windows, you can press the print screen key, which copies the screen to the windows clipboard and copy into pretty much any program that handles images, easiest way to get it is open up ms paint, it pastes into there full size, from thre you can reduce enlarge it as you like.
