Home › Forums › Printing Discussions › Mimaki Printers › Everythings turning green
Posted by Steve Kullman on 6 April 2009 at 21:19I recently upgraded to Onyx7 rip and am having difficulty getting my
JV3-160S printing properly. No matter what I set it to, all the images appear greenish. Vector Looks ok but images are horible.Phill Fenton replied 16 years, 9 months ago 5 Members · 7 Replies -
Are you sure it’s the RIP at fault. Could it be a cross contamination of ink – e.g black getting into the c,m or y?
onyx works fine with the jv3-160s, i have used it myself.
so hows the ‘Test Print’?
This is way beyond a lighting thing all the people in the print are green.
The test print is perfect. It is definitely a profile issue and i cant seem to find proper profiles for Onyx 7 and JV3 160s. Not even Mimaki has them.
Does anyone have a working setup they can send me or tell me your printer settings, particularly output settings and rendering settings.
Something is definitely amiss here. -
Took a while but figured out that the previous operator had inadvertently switched the light cyan and light magenta around and thus the green image.
Swapped the little reservoirs around and did a little purging, problem solved. -
Well done for finding it Steve, it’s so often the little things that confuse cos we’re tending to look at complex stuff beyond that.
Ian :lol1:
quote Phill:Are you sure it’s the RIP at fault. Could it be a cross contamination of ink
Told you so 😛
