Home Forums Software Discussions Flexi Sign Software Etch Cutting without border – help please?
  • Etch Cutting without border – help please?
    Posted by Robert Neill on 15 October 2015 at 19:52
    Hi guys…. looking for some help.
    I have a window to etch with 610mm etch. But i want to cut lettering out of the centre of the etch material, but the problem is that i want to use the whole width of the etch…. as in i dont want to cut a border. So how would i go about that using Flexi 10 ?
    Any Ideas ?
    Robert
    Gil Johnson replied 10 years, 2 months ago 3 Members · 6 Replies
  • Kevin Flowers
    15 October 2015 at 21:07
    use 8.5 myself but if you just turn weed border off, it should just cut the lettering
  • Robert Neill
    15 October 2015 at 21:21
    Hi Kev…. ye it will just cut the lettering without weed border on, but i want the letters positioned in the centre of the vinyl, so thats the issue.
    Robert
  • Gil Johnson
    15 October 2015 at 22:35
    Hi Robert,
    Just put a point in each corner of the design, the plotter will not cut anything but a point will be recognised by cut manager and therefore cut your text in the centre, or you could draw a single line to the window width say 590mm deep and finish off the ends by hand, that way you have the the material cut to window size but still at 610mm roll width.
    Hope this helps?!
    Gil
  • Robert Neill
    15 October 2015 at 22:46
    Ah right ye i think i get what your saying…. great ideas
    Thank you Gil
    Much appreciated
  • Robert Neill
    16 October 2015 at 19:13
    Hi Gil….just trying this out, could you explain your second idea please, the one about the line, i dont quiet get that one.
    Robert
  • Gil Johnson
    17 October 2015 at 18:23
    Hi Robert,
    Say if your window is 1m wide and you want to use the full 610mm material width, draw the vertical lines at 1m apart X 580mm deep, add your logo / text to the centre of the etch and cut, then finish vertical lines by hand – 15mm top and bottom.
    Hope that is clearer?!
    Gil
