Home Forums Sign Making Discussions General Sign Topics erecting metal lecterns
  • erecting metal lecterns
    Posted by MikeeWalsh on 14 September 2009 at 16:54
    I Have a steel lectern that i need to fit that has 2 posts with a 250mm x 600mm base plate. i will be burying the base plate 600mm deep with 1000mm above ground. The top plate will be at an angle of 30 degrees so not really much wind resistance. I was thinking that i might get away with just back-filling with soil and compacting rather than using concrete. Can anyone let me know if this would work or should i use concrete.
    Kevin Flowers replied 16 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
  • Kevin Flowers
    14 September 2009 at 19:57
    Mike
    the problem is vandals, once they start it moving they will have it out of the ground. Just use a couple of bags of post mix will do the job fine
