Home Forums Software Discussions Signlab Software EPS into Signlab ‘ungroup’ problem
  • EPS into Signlab ‘ungroup’ problem
    Posted by Nigel Hindley on 10 March 2010 at 16:47
    I have been having problems getting eps files into signlab (usually there is no problem) this one has come from a design house and it seems tricky after re saving a few times the images now import but they are locked and I cant seem to unlock them – any one any ideas?
    Nigel
    Peter Dee replied 15 years, 7 months ago 5 Members · 6 Replies
    10 March 2010 at 17:01
    Try the "break path" function under "arrange"
  • Nigel Hindley
    10 March 2010 at 17:29
    Hi Phil,
    Cheers but I tried that, ……however I think I have cracked it. I tried the clipping whatever that is? nothing, that is unless you click ungroup first.
    So ungroup then clipping, then clipping clear and that’s it!
    I have only tried 2 of 13 files so far but seems its sorted it! Never come across that before!
    Nigel
    10 March 2010 at 17:48
    its quite common for designers to use clipping paths,
    it is a very useful tool especially in signlab.
    For instance if you just want part of a picture or a texture to fill a letter or a shape put the shape in front off whatever you need to clip, select both and apply clipping.
    just in case you didnt know what is used for.
  • Nigel Hindley
    10 March 2010 at 19:38
    quote Peter Normington:
    Cheers Peter, sounds handy, never realized what it wwas for!
    Nigel
  • Shane O Grady
    18 May 2010 at 13:45
    Nice 1 Peter, have Signlab 5 years and i learn something new every day about it !!!!
  • Peter Dee
    18 May 2010 at 15:48
    Use clipping in Signlab to show only part of a bitmap without the square white background. Draw any shape, oval or whatever, lay it over the bitmap, select clipping and hey presto.
