• Posted by millie on 23 July 2003 at 07:53
    Hi All,
    We ahve been sent an eps file and need to open it Corel 10, have tried importing and opening as eps and AI but no luck. Can anyone help by explaining how to open it?
    Many thanks
    Ian 😳
    millie replied 22 years, 5 months ago 6 Members · 6 Replies
  • John Childs
    23 July 2003 at 08:12
    I can’t explain how to do it – no experience of Corel 10, but if you post the file I’ll see if I can open it and then save to Corel 8 which you should then be able to open in 10.
    It’s a bit long winded but it might work.
  • Steve Broughton
    23 July 2003 at 08:51
    Ian are you just getting a grey square? if so this is how you should import it, this is corel 9 but I’m sure 10 is the same (?)
  • WP_Graphics
    23 July 2003 at 10:49
    I’m with steve on this,
    AI EPS’s are different from the “other” eps’s that you so often find when coming from MAC’s and such the like.
    Gav
  • Martin C
    23 July 2003 at 10:56
    Go into Your Computer, find the Script file and the EPS, copy it and then you can paste it into a new Corel page.
  • Adrian Howard
    23 July 2003 at 12:05
    dont import use open and it will work
    and you should be prompted with open as curves or text
    choose curves
    give it a try
  • millie
    23 July 2003 at 16:01
    Many thanks to all who helped, got it open with Steves help.
    Charlotte ( Ian’s Better Half) 😉
