Home Forums Software Discussions General Software Topics Enlarging jpg Images WITHOUT Losing Clarity?
  • Enlarging jpg Images WITHOUT Losing Clarity?
    Posted by John Cooper on 27 April 2008 at 14:23
    Hi Guys
    I have a stack of jpg image files that look great great. I want to enlarge them so they still look good! I know the usual result is horrible blocky/fuzzy edges.
    These pictures are destined for T-Shirts so the images don’t need to be of photo quality.
    Is there any software that is designed for this purpose?
    Rodney Gold replied 17 years, 4 months ago 16 Members · 18 Replies
  • 18 Replies
  • Martin Grimmer
    27 April 2008 at 14:40
    John,
    I use photozoom pro after a recommendation on here. Seem to recall about £100.
    http://www.benvista.com/main/content/co … ozoompro_1
    Not perfect but does a very good job.
    You can also check out Genuine Fractals – tested that a long time ago and was pretty good.
    Hope helps
    Martin
    27 April 2008 at 17:43
    John, sometimes you can get away with just increasing the resolution in a photo program, especially when they aren’t going to be blown up that much, can you post a sample image, maybe you will get some examples of what can be done.
  • Richard Urquhart
    27 April 2008 at 17:50
    alien skin do a plug in called Blow up
    BlowUp offers the highest quality image resizing available, better than bicubic interpolation and any other third party solution. BlowUp makes advanced image scaling easy, preserves smooth, crisp edges and lines, and creates four times (1600% area) enlargements from any image without jagged artifacts or halos. In some cases, BlowUp can enlarge up to six times (3600% area) without obvious artifacts
  • John Harding
    27 April 2008 at 19:52
    quote :
    oooh somones swallowed a dictionary 😀 😀
  • Richard Urquhart
    27 April 2008 at 20:06
    Amazing what copy and paste can do John.
    If you look at the text you can tell it did not write it as the spelling is correct and has punctuation in the correct places.
    27 April 2008 at 23:07
    quote Martin-G:
    John,
    Martin
    I use photozoom pro as well. Excellent for doing really big stuff. Corel Photopaint X3 is good enough to enlarge most Images for printing to shirts and stuff though.
  • Gareth.Lewis
    28 April 2008 at 13:17
    I tried photozoompro myself a couple of months ago. Then I tried to email the increased res. file to my outsourced large format printing co. in England………no way, hose.
    If you have in house printers all well and good but any clues as to what to do if you havent?
  • Martin Grimmer
    28 April 2008 at 15:04
    quote Gareth Lewis:
    Gareth – if you have photoshop, you could try the "save for web". This gives you a preview as to what the finished version would look like saved at a lower level (guess more compression) – you can normally dramatically reduce file size this way. If all else fails, burn larger file to disk and post to your wide format printers – will only take extra day (although can be a pain if done too often).
    Martin
  • Steve McAdie
    28 April 2008 at 15:15
    Some printers if not all should be able to enlarge image for you. Some may charge for this others might not. I have sent disks before in the post only drawback is it takes a day or so longer than e-mailing. I prefer to do any scaling myself but that’s cos I’m a control freak
  • Ian Higgins
    28 April 2008 at 18:11
    The latest Signlab Print & Cut has a handy tool for doing it
  • Alexis Davis
    9 August 2008 at 00:15
    I find just resampling using the photoshops bicubic smoother does a good enough job, obviously it can only blow up so much but seeing as you only want to blow up to go on tshirts Im sure that should do the job if its not ridiculously small.
  • Jason Xuereb
    9 August 2008 at 05:44
    If you are going to use photoshop increase the image 5% at a time. It reduces the distortion compared to trying to increase it by 100% in one go.
    We use photozoom pro here though.
    Although we did a banner the other day 5m by 5m and scanned it in from a negative.
  • Graeme Harrold
    9 August 2008 at 07:13
    Done something similar in Corel Photopaint. Taken a small image and changed the dpi setting first, then altered the size in mm to what was required. It does help with enlarging, but can make the image a little fuzzy, as if it has a soft focus.
  • Jason Davies
    9 August 2008 at 07:55
    You could even print them out in hi-res and re-scan at a high dpi, problem solved.
    Jason
  • Neil Herbert
    9 August 2008 at 20:54
    quote Gareth Lewis:
    Try http://www.cutesendit.com worth signing up and downloading free desktop program.
    Hope this helps
    Neil
  • Peter Dee
    11 August 2008 at 07:37
    You can also send large files over Skype.
    http://www.skype.com/intl/en-gb/allfeat … etransfer/
  • Lee Attewell
    11 August 2008 at 08:42
    We send massive files via Windows messenger…Works well 🙂
  • Rodney Gold
    12 August 2008 at 05:20
    Use Xnview , a freeware utility , resize uses the Lanczos algorithm , it has many other algorithms/options too.
    Aso a great Coreldraw and other graphics viewer
    http://www.xnview.com
