Home Forums Software Discussions General Software Topics Engravelab – software help PLEASE !! …..
  • Engravelab – software help PLEASE !! …..
    Posted by Adrian Neill on 27 May 2008 at 08:53
    Morning everyone ……. right i’ve got a basic problem with Engravelab
    which i’m sure someone will know the answer too.
    I’ve got to engrave a few brass plates with a basic single-line engraver
    font and outline ……. problem I have is I don’t seem to be able to send
    the job to the engraver without it coming out ‘filled in’.
    When I go to "cut" then "create tool path" I get the following options :
    – Online
    – Male
    – Female
    – Fill
    ….. what one do I choose ?? ( I normally choose ‘Fill’ for normal engraving)
    Then I go "cut" – "plot" ….. is there anything that should or shouldn’t be highlighted ??
    As mentioned when I send this job to engrave it wants to engrave the
    whole block rather than just the outlines ……..
    Hope that makes sense ….. any help appreciated. 😀
    Ian Holmes replied 17 years, 6 months ago 3 Members · 5 Replies
  • Neil Herbert
    27 May 2008 at 10:39
    Adrian
    I would try the online option.
    Hope this helps
    Neil
  • Adrian Neill
    27 May 2008 at 10:43
    Hi Neil …. exactly what i thought ….
    what about the next step ?? when I send as normal it still wants to engrave
    the whole block and not just the lines. 😕
  • Neil Herbert
    27 May 2008 at 22:16
    Are u sure that the lines are separate, how big is the text ?
  • Adrian Neill
    28 May 2008 at 06:50
    Hi Neil ….. the text was only about 4mm tall.
    I did some ‘jiggery pokery’ and managed to get it to work.
    Not sure if i did it right but it seems to work. I’ll see how i get on today.
    Cheers for your help. 😀
  • Ian Holmes
    3 June 2008 at 19:44
    you don’t need to create a fill to SINGLE line fonts, just select it & go to plot menu (not the scissor symbol on the tool bar) there you will see a tick next to engrave un-tick then re-tick again, and a second window will pop up there you can either select to: cut fill / cut outline / or cut both
    you normally cut fill when working with true type etc leaving the cut outline un-ticked so you don’t add unreq’d thickness to the lettering
    just remember to use the plot command from the top menu not the scissor from the toolbar as this doesn.t bring up the options
    Have fun
