Home Forums Printing Discussions Printer Ink Eco Sol Inks and Clearcoated Decals?
  • Eco Sol Inks and Clearcoated Decals?
    Posted by OwenTaylor on 18 May 2008 at 21:02
    Hi all,
    I have been asked to produce a set of full colour decals that will then be clearcoated over afterwards to protect them. I’m just a bit worried about the Eco Sol inks reacting with the clearcoat and damaging the decals. I considered laminating them but they must be as thin as possible to avoid the need for multiple coats of lacquer…
    Does anybody have experience of how eco sol inks react with automotive paints and lacquer etc?
    Any advice is much appreciated. Thanks in advance,
    Owen
    Craig Gibson replied 14 years, 11 months ago 9 Members · 14 Replies
  • 14 Replies
  • Richard Urquhart
    18 May 2008 at 21:16
    frog juice works fine and also clearseal laminating fluid and i have also used 2k lacquer but would say frog juice is the way to go
    rich
  • OwenTaylor
    18 May 2008 at 21:18
    😀 that was quick – not just me here late on a Sunday evening then…
    Thanks for the advice,
    Owen
    18 May 2008 at 21:27
    only time i have had a problem was when the lacquer was thinned to much causing the vinyl to pull.
    rich just a by the way don’t use application tape over frog juice on a print, nightmare story if you want.
  • Ian Bingham
    19 May 2008 at 08:16
    When using clear coat or lacquer use a fine sealing dust first then layer it in thin coats, never had any problems with doing it this way
    Ian
  • Craig Gibson
    8 January 2011 at 17:45
    I have a guy who wants a print on the bonnet of his stock car he is then going to lacquer whole bonnet. Would this be ok? Using Eco sol max inks.
    Craig
    8 January 2011 at 19:31
    i would give him any old print you have lying around. hand him it and tell HIM to spray it as a test. if hes happy to go ahead then fine. me personally. i wouldn’t liquid laminate with anything other than purpose made stuff. I’m in no way saying you cant, i just mean ide rather do the job right at extra expense "of your own" than risk it to save the customer a few bob.
    8 January 2011 at 19:49
    I dont think this is to save the customer money Rob,
    a print can be laquered so that it "becomes" part of the paint, and not a "sticker"
    I have supplied print for bikers, who then apply to the panel before applying the final coat of laquer,
    I am told that they give it a "mist" coat first then a final spray.
    But, never the less, a good idea to to a test first,
    8 January 2011 at 20:27
    yeh i know what you mean peter. and if this is the case, fair do…
    i kinda sed read and took it was being done because there wasnt laminating fascility or that customer may not want to pay… maybe i should slow down my reading. lol
    i have saw them do it on programs like orange county choppers, west coast customs etc… think i read Beej Curtis doing it too, which might be wrong as he normally does everything freehand. anyway…
    anyway… as said… test test test… all chemicals have different content in it and could activate the ink to smudge, blurr, run whatever….
  • Craig Gibson
    8 January 2011 at 21:08
    Thanks guys, Peter your right it’s not a cost thing and I could laminate.
    He wants the print on and lacquered in.
    I thought it sounded ok but was worried about any possible reaction.
    If it were just vinyl can this be lacquered in or would exposure to heat cause the vinyl to move and possibly break the lacquer?
    8 January 2011 at 21:20
    allow the vinyl adequate time to settle. ide guess minimum of 24hrs.
    other than microns in thickness which is still going to be visible i recon regardless. laminate lacquer…
  • Craig Gibson
    8 January 2011 at 21:25
    Thanks Robert. Will test first, the light mist first makes sense to.
  • Stephen Morriss
    10 January 2011 at 12:28
    I’ve used printed and cut vinyl on bikes quite a lot and they’ve all been fine apart from areas were the vinyl was stretched too much, the solvent in the lacquer softens the glue for a while so it’ll pull back out.
    Cast may not have this problem but I’ve never tried it.
    The painter has always given it a dusting coat first as well.
  • Roger Clements
    10 January 2011 at 13:37
    Craig…I’ve been doing graphics etc for a custom spray shop for a few months now and all my print is non laminated eco-sol. The paint shop thinks the stuff is the dogs’ danglies and the only problem…note single decal problem… from dozens of prints done was his fault (he admitted it was his fault) and due to poor application. And yes he laquers all the stuff I send him.
  • Craig Gibson
    10 January 2011 at 14:06
    thanks for the reply guys, gives me a bit more confidence
