Home › Forums › Software Discussions › General Software Topics › Easysign error
Easysign error
Posted by Dan Saunders on 17 September 2007 at 19:42Hi i was just wondering if anyone here who may have used Easysign come across the error Out of memory when sending image to print ?
Dan
Ian Johnston replied 18 years, 2 months ago 4 Members · 5 Replies -
I went to the Easysign website and searched the FAQ’s, no joy, so maybe your pc is running low on available memory.
You said it happened when you go to print, if you are sending to a wide format printer and not a desktop A4 printer then you could well be out of memory available for that task.
What are your pc specs?
Nigel -
Hello Nigel,
Been running easysign ok for weeks but for some reason its now acting strange…..Pc’s AMD 2000+ 1.67 Ghz with 2 gig of ram !Should be enough power there
see the reply on link below that i gave this may cure it if you are using easysign 32 print sever
http://www.uksignboards.com/viewtopic.p … highlight=
email me if you need more help
Ian
Don’t use easysign so don’t know if this will help but are all the old jobs that you have printed still saved on your scratch disc? If they are then you may have to delete some of them to free up some space or increase the size of your scratch disc on the hard drive.
Mean to say earlier, empty your easysign temp file folder, it doesn’t self empty.
Ian
