Home › Forums › Sign Making Discussions › Vinyl › Easy temporary removable vinyl
Posted by Tim de Beir on 31 July 2013 at 08:34I am looking for a easy removable vinyl, wich can be easily removed by my customers.
If possible Avery – Oracal or 3M series vinylThanks,
Tim
Bruges BelgiumVic Adair replied 11 years, 10 months ago 5 Members · 7 Replies -
printable or standard?
Metamark do a 6 month removable i think its MD3R. I used to get removable standard from hexis…I think its only in a few colours and matt. If they dont do it anymore…I think I got last lot from robert horne..Cheryl -
not printable, white color… Metamark is not a brand well known over here!
Well printable will work as well if you only need white
Graphityp do a good one and their based in Belgium I think if that helps
John 😀
Tim if you are going to look up the company John has mentioned then look for Grafityp 😉
Nigel
okay thanks!
Nigel, have contacted (twice already) igepa let’s hope they give me an account so I can order online…
Nigel another question: can I use medium tack application tape?
Tim to use with the removable series vinyl then medium tack application tape should be fine.
Nigel
Does anyone do a clear 6 month removable vinyl and is it safe enough on a Metallic finish
