• Dye Sub Tiles
    Posted by Justin Mann on 15 April 2008 at 14:34
    Can anyone recommend a spray coating to protect the surface of glossy dye subb’d tiles?
    Also, I have been looking at software options to split a picture into sections for a Mosaic effect, i.e. 2 rows 6 tiles etc. and wondered what anyone else uses to do this. I know you can split the picture in Photoshop but I was looking at things like Split & Tile which seem very good, my only consideration is allowing for the small gaps in between the tiles when fixed to the wall.
    Thanks in advance!
    Justin 🙂
    Steve Underhill replied 17 years, 8 months ago 4 Members · 6 Replies
  • Steve McAdie
    15 April 2008 at 14:52
    Hi Justin,
    This may be of interest to you. I had a look at it when it was version 7 sounds like it may be what your after.
    http://www.noveltycentral.com/
  • Calvin.Turner
    16 April 2008 at 00:08
    I’ve used photoshop for doing mine so nothing new there.
    What is it you are wanting to protect them against?
  • Justin Mann
    16 April 2008 at 08:02
    Thanks for the replies. I used Photoshop to slice the image which works well and then just copied each section out, size of the section seemed a little too large but that was prob. my fault. I read a tutorial that suggested saving for web and this put each slice separately into a directory, this was very useful but couldn’t handle very large files.
    Customer asked about the scratch resistance of the tile surface as they seemed easily scratched. They will be used as a kitchen splash-back. I guess UV resistance could also be a problem so maybe frogjuice or something might help?
    Cheers,
    Justin 🙂
  • Steve Underhill
    16 April 2008 at 08:39
    Dye sub ink never seems to fade.
    Not on anything I put in the window anwyay, its been in there 2 years with direct sunlight on it.
    This is placemats and coasters and mugs.
  • Justin Mann
    16 April 2008 at 08:45
    Cheers Steve. I’ve been led to believe that Subli ink will fade in UV after 2/3 years. We get very long days here in the summer, thus greatly increased amounts of UV. I was told to expect 6 months before fading started.
    I think it’s one of those try it and see situations. I can’t see the tiles being in direct sunlight.
    Justin 🙂
  • Steve Underhill
    16 April 2008 at 08:53
    I actually thought they would fade but they havent yet, maybe after so long they will but everything else in the window did but those.
    Time will tell.
